in a new project (v 7.7.1), I have defined a DocumentType with name "Seo" used for composition. In this DocumentType I used Vorto to define "metaTitle" property.
I used "Seo" to compose "Home" DocumentType and others.
The MoldelsBuilder generates:
- ISeo interface
- Seo class that implement ISeo
- Home class that implement ISeo and the getter of any ISeo property call a specific method (es. GetMetaTitle()).
Now, I wold like to implement custom MetaTitle property with string return type (natively ModelsBuilder generates Vorto properties with Our.Umbraco.Vorto.Models.VortoValue return type) and fallback to main language.
I tried to implement a partial class (in App_Data folder) with my MetaTitle property marked with ImplementPropertyType("metaTitle") attribute.
In this case ModelsBuilder not implement MetaTitle property in ISeo interface, Seo and Home classes.
I want to use my MetaTitle implementation in every View that use a Model that implement ISeo.
Are there any solution to indicate to ModelsBuilder to generate MetaTile property in ISeo interface and in Home class with my custom implementation?
ModelsBuilder with Vorto and Composition
in a new project (v 7.7.1), I have defined a DocumentType with name "Seo" used for composition. In this DocumentType I used Vorto to define "metaTitle" property. I used "Seo" to compose "Home" DocumentType and others.
The MoldelsBuilder generates: - ISeo interface - Seo class that implement ISeo - Home class that implement ISeo and the getter of any ISeo property call a specific method (es. GetMetaTitle()).
I tried to implement a partial class (in App_Data folder) with my MetaTitle property marked with ImplementPropertyType("metaTitle") attribute. In this case ModelsBuilder not implement MetaTitle property in ISeo interface, Seo and Home classes. I want to use my MetaTitle implementation in every View that use a Model that implement ISeo.
Thanks, Davide
Any idea on how to resolve this problem? I'm in the same situation
