  • Peter Cort Larsen 421 posts 1038 karma points
    Sep 29, 2017 @ 15:33
    Peter Cort Larsen
    UmbracoApiController: beginner help
    My controller never gets reached. I am new at MVC so i need a little help.
    I have created a Controller under : App_Code > Controllers. Its called ''LoginApiController''
    I have a angular script, thas calls the Controller
    I have a Partial View for the html.
    But i never reach the controller.
    Controller
    using System.Linq; using System.Net.Mail; using System.Web; using System.Web.Mvc; using Umbraco.Web.WebApi;
    namespace MyNameSpace {
    public class LoginApiController : UmbracoApiController { [HttpPost] public bool Send(LoginFormModel model) { var CustomerID = model.CustomerID; var Password = model.Password; return true; } }
    public class LoginFormModel
        public string CustomerID { get; set; }
        public string Password { get; set; }
    Angular
    app.controller("LoginCtrl", function ($scope, $http) {
    $scope.CustomerID = '';
    $scope.Password = '';
    $scope.send = function () {
        if ($scope.loginForm.$valid) {
            var data = { CustomerID: $scope.CustomerID, Password: $scope.Password };
            $http({ method: 'POST', url: '/umbraco/api/LoginApi/Send/', data: data }).success(function (data) {});
    View
    <form novalidate ng-submit="send()" name="loginForm" ng-controller="LoginCtrl">
                <fieldset>
                    <div class="row">
                        <div class="col-s-6">
                            <label for="txtName">@Umbraco.Field("#Customer_name", altFieldAlias: "Customer ID"):</label>
                            <input ng-model="txtCustomerID" type="text" id="txtCustomerID" value="" required placeholder="@Umbraco.Field(" #Customer_name", altFieldAlias "Customer ID" )">
                            <label for="txtName">@Umbraco.Field("#Password", altFieldAlias: "Password"):</label>
                            <input ng-model="Password" type="password" id="txtPassword" value="" required placeholder="@Umbraco.Field(" #Password", altFieldAlias "Password" )">
                </fieldset>
                <div class="form-actions">
                    <input type="submit" class="btn" value="@Umbraco.Field(" #Login", altFieldAlias "Login" )" />
            </form>
    Sep 29, 2017 @ 15:38
    Peter Cort Larsen
    its like the form isnt submitting at all.
  • Alex Skrypnyk 6181 posts 24242 karma points MVP 8x admin c-trib
    Sep 29, 2017 @ 16:29
    Alex Skrypnyk
    Hi Peter
    Can you check that angular works fine on your page?
    Some other angular logic is working fine?
    Alex
    Sep 29, 2017 @ 16:53
    Peter Cort Larsen
    A simple check :
    i added this after the body tag
    {{3 + 3}}
    and it returns : 6
    so its working fine.
  • TheCodeMan 7 posts 97 karma points
    Oct 01, 2017 @ 12:31
    TheCodeMan
    Hello Peter
    Just wanted to comment on your code.
    You can try to set up at route in your controller like this example http://www.jondjones.com/learn-umbraco-cms/umbraco-developers-guide/umbraco-web-api/how-to-create-a-web-api-in-umbraco-in-less-than-5-minutes
    In your angular code try to write to the console example console.log("If i hit F12 in the browser i can see this if I am in the $scope send function.")
    Set the console.log under $scope.Password and under $scope.send = function () { and under if ($scope.loginForm.$valid) {... And finally in your .success function.
    Hope it helps
    Best regards Jakob
    Oct 02, 2017 @ 15:31
    Peter Cort Larsen
    Thanks for your answers.
    After returning a value inside the success function, i could see that everything was working.
    So the console.log in the proper place, did the trick.
