Create new umbraco section throws "Index was out of range Error"
Section creation code:
using umbraco.businesslogic;
using umbraco.interfaces;
namespace CCB.Web.App_Plugins.ColorCombinations.Application
[Application("colorCombinationsSection", "ColorCombinationsSection", "icon-book", 10)]
public class ColorCombinationsSection : IApplication
Error:
2017-10-06 10:20:08,791 [P67404/D7/T74] ERROR Umbraco.Web.Editors.SectionController - Unhandled controller exception occurred
System.ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: index
at System.ThrowHelper.ThrowArgumentOutOfRangeException(ExceptionArgument argument, ExceptionResource resource)
at Umbraco.Web.Editors.SectionController.GetSections()
at lambda_method(Closure , Object , Object[] )
at System.Web.Http.Controllers.ReflectedHttpActionDescriptor.ActionExecutor.<>c__DisplayClass10.<GetExecutor>b__9(Object instance, Object[] methodParameters)
at System.Web.Http.Controllers.ReflectedHttpActionDescriptor.ActionExecutor.Execute(Object instance, Object[] arguments)
at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
at System.Web.Http.Controllers.ApiControllerActionInvoker.<InvokeActionAsyncCore>d__0.MoveNext()
at System.Web.Http.Filters.ActionFilterAttribute.<CallOnActionExecutedAsync>d__5.MoveNext()
at System.Web.Http.Filters.ActionFilterAttribute.<ExecuteActionFilterAsyncCore>d__0.MoveNext()
at System.Web.Http.Controllers.ActionFilterResult.<ExecuteAsync>d__2.MoveNext()
at System.Web.Http.Filters.AuthorizationFilterAttribute.<ExecuteAuthorizationFilterAsyncCore>d__2.MoveNext()
at System.Web.Http.Controllers.ExceptionFilterResult.<ExecuteAsync>d__0.MoveNext()
Well, Umbraco threw this error because I hadn't the Tree controller included in the plugin folder, what was not necessary for the versions below 7.7.0. But now if you don't pass the nodes of the tree it will throw "Index Out of range" error.
And also make sure that your application alias is same:
[Tree("ApplicationAlias", "exampleTree", "Example")]
[PluginController("ExampleName")]
public class ExampleTreeController : TreeController
Now with the new versions >= 7.7.0 you should create a TreeContoller for each custom section, which wasn't necessary for the previous versions (if one section hadn't a TreeController, Umbraco simply used to show a blank page without any tree). But now, if you don't create a tree controller, Umbraco throw this error.
Alias: every section has an Alias called ApplicationAlias. Make sure that you include this alias properly when you create the TreeController, otherwise, it will throw an error.
Creation of section (this class create a new section):
namespace CCB.Web.App_Plugins.Products.Application
[Application("productsSection", "Product", "icon", 9)] //productsSection is the Alias of this Section/Application
public class ProductSection : IApplication
Section TreeController (umbraco call this controller's api to get the structure of the section tree, if don't find -> throw out of index error):
using System.Web;
using System.Web.Mvc;
using umbraco;
using umbraco.BusinessLogic.Actions;
using Umbraco.Core;
using Umbraco.Core.Services;
using Umbraco.Web.Models.Trees;
using Umbraco.Web.Mvc;
using Umbraco.Web.Trees;
namespace CCB.Web.App_Plugins.Products.Controller
[Tree("productsSection", "ProductsTree", "Products Section")] //productsSection is the ApplicationAlias, make sure that, is the same as you defined to the section creation class
[PluginController("Products")]
public class ProductsTreeController : TreeController
protected override TreeNodeCollection GetTreeNodes(string id, FormDataCollection queryStrings)
return nodes;
protected override MenuItemCollection GetMenuForNode(string id, FormDataCollection queryStrings)
return menu;
Error:
Why umbraco throws this error ??
-Thanks
Can you expand a little on this? What do you mean "pass the node of the tree"? Also, application alias is the same as what?
Now with the new versions >= 7.7.0 you should create a TreeContoller for each custom section, which wasn't necessary for the previous versions (if one section hadn't a TreeController, Umbraco simply used to show a blank page without any tree). But now, if you don't create a tree controller, Umbraco throw this error. Alias: every section has an Alias called ApplicationAlias. Make sure that you include this alias properly when you create the TreeController, otherwise, it will throw an error.
I hope this will help you. :)
What code should go in the 2 methods?
