  • Rayyan 46 posts 238 karma points
    Oct 13, 2017 @ 07:06
    Rayyan
    Umbraco Local Connection String Path
    Hello there,
    I have a big sql file that i need to run in Umbraco database that located on the local machine using a tool as shown in the attached screenshot.
    How to figure out what is the connection string for that database?
    BigRunner Screenshot
    Thank you,
  • Michaël Vanbrabandt 863 posts 3348 karma points c-trib
    Oct 13, 2017 @ 07:44
    Michaël Vanbrabandt
    Hi Rayyan,
    to know the connection string of your Umbraco website, just go to the web.config file and search for ConnectionString.
    Then you will see something like this:
    <connectionStrings>
        <remove name="umbracoDbDSN" />
        <add name="umbracoDbDSN" connectionString="server=YOURSERVER;database=YOURDB;user id=YOURUSER;password='YOURPWD'" providerName="System.Data.SqlClient" />
        <!-- Important: If you're upgrading Umbraco, do not clear the connection string / provider name during your web.config merge. -->
      </connectionStrings>
    Then just copy and paste the connectionString property to your tool.
    Hope this helps.
    /Michaël
    Oct 13, 2017 @ 08:05
    Rayyan
    Thanks Michael for your help, I have tried that already but does not work. Here's my connection string;
    <connectionStrings>
            <add name="umbracoDbDSN" connectionString="Data Source=|DataDirectory|\Umbraco.sdf;Flush Interval=1;" providerName="System.Data.SqlServerCe.4.0" />
    First i got this error (Keyword not supported: 'flush interval'.) so I have removed the (flush interval') and added (Persist Security Info=False;), but couldn't make the connection.
    I used this:
    Data Source=umbraco.sdf;Persist Security Info=False;
    And this:
    Data Source=C:\Umbraco.sdf;Persist Security Info=False;
    Any idea please, Thank you
    Oct 13, 2017 @ 08:13
    Michaël Vanbrabandt
    Hmmm you are using the SQL CE which is a file, I guess that is your issue.
    Are you sure that the BigRunner tool can work with SQL CE?
    /Michaël
    Oct 13, 2017 @ 08:44
    Michaël Vanbrabandt
    Rayyan,
    from what I can see in the docs of the BigRunner Tool, it will only work with a SQL Server instance.
    /Michaël
    Oct 13, 2017 @ 09:03
    Rayyan
    Thanks Meesh! Do you know any alternative tools to execute big script?
    Oct 13, 2017 @ 09:08
    Michaël Vanbrabandt
    Which work using SQL CE? Hmm not directly, maybe you can convert your SQL CE to a SQL Server instance?
    /Michaël
    Oct 13, 2017 @ 10:03
    Alex Skrypnyk
    Hi Guys
    You can use "SqlCeToolbox" for moving database from MSSQL to SQLCE or back:
    https://github.com/ErikEJ/SqlCeToolbox
    Alex
    Oct 13, 2017 @ 18:01
    Rayyan
    Thank you guys, I think I will remain using (Compact View).
