I have to implement a back office section that will need to maintain complex data with full CRUD and complex joins, pivot grids, etc. I have the Custom Tables in my Umbraco database and I can use them with full CRUD and I have the controls that I will be using which are Razor server side controls. The problem that I am having is that I cannot figure out how, or if possible to use controllers and Razor views in the backoffice custom section.
I have successfully created a section and a tree and an .html page when the tree node is clicked on. This all works great, but unfortunately I cannot find a way to use razor pages in the section. I have implemented an iframe successfully, but that really isn't the way that I wanted to go.
Any suggestions would greatly be appreciated. Thanks so much in advance.
Backoffice Sections and Razor
My advice would be to implement in Angular.
https://our.umbraco.org/documentation/Tutorials/Creating-a-Custom-Dashboard/
http://www.enkelmedia.se/blogg/2013/11/22/creating-custom-sections-in-umbraco-7-part-1.aspx
http://www.enkelmedia.se/blogg/2013/11/22/custom-sections-in-umbraco-7-%E2%80%93-part-2-the-views.aspx
However it is possible to render razor in the backoffice creating custom trees
http://jondjones.com/learn-umbraco-cms/umbraco-developers-guide/customising-umbraco-ui/how-to-display-an-mvc-view-in-the-umbraco-backend
This has already been discussed in this post:
https://our.umbraco.org/forum/umbraco-7/developing-umbraco-7-packages/61229-MVC-Razor-Views-in-backend
Good references, I appreciate it.
