  • Thomas Beckert 193 posts 469 karma points
    Nov 17, 2017 @ 16:59
    Thomas Beckert
    Custom Section Dashboard without dashboard.config
    I have a Dashboard at /App_Plugins/OSKSection/edit.html
    The tabbing is setup in the edit.html, so I don't want to use the dashboard.config to setup the tabbing and so on.
    But how do I tell umbraco to use mit html-file? In the dashboard.config I only can refer to the file with the option of tabbing and this causes a double tabbing in my view.
    Any ideas how to solve this?
    Thanx in advance -
    Tom
  • Søren Kottal 713 posts 4571 karma points MVP 6x c-trib
    Feb 05, 2018 @ 18:40
    Søren Kottal
    Hi Thomas
    I don't think you can do that, because dashboards are tabbed in context to the section they belong to.
    So ie. you have "Get started", and "Redirect Url Management" as tabs on the content dashboard in a clean install. But they are seperate dashboards.
    Feb 07, 2018 @ 11:08
    Thomas Beckert
    Hi, Soren,
    thank you for you feedback. I think you are right. I have to do it in another way...
