Misterious padding added on top with an '__mcenew' id
Hi, I have a problem, for some reasons when i try to add an image in a RTE (Rich Text Editor), an id called '__mcenew' appears on the top of my image, which gives me a padding on top. How can I solve this?
I work in umbraco 7.6.1.
I tried to do as in the below links, but it doesn't work:
I wouldn't have thought the id would be giving the padding, are you sure it isn't the p tags that TinyMCE is applying around the image?
Either way, TinyMCE can be a little tricky due to it adding p tags etc. The quickest solution would be to simply update your CSS to remove the extra padding.
link1 link2
Hi Valentin,
ptags that TinyMCE is applying around the image?Either way, TinyMCE can be a little tricky due to it adding p tags etc. The quickest solution would be to simply update your CSS to remove the extra padding.
Thank you Ben, this worked.
Hi Valentin,
Glad it worked for you! Could you be so kind as to mark the thread as solved please?
Thanks!
