System.InvalidOperationException: This SqlTransaction has completed; it is no longer usable.
at System.Data.SqlClient.SqlTransaction.ZombieCheck()
at System.Data.SqlClient.SqlTransaction.Commit()
at Umbraco.Core.Persistence.Database.CleanupTransaction()
at Umbraco.Core.Persistence.Database.CompleteTransaction()
at Umbraco.Core.Scoping.Scope.DisposeLastScope()
at Umbraco.Core.Scoping.Scope.Dispose()
at Umbraco.Core.Persistence.UnitOfWork.ScopeUnitOfWork.DisposeResources()
at Umbraco.Core.DisposableObject.Dispose(Boolean disposing)
at Umbraco.Core.DisposableObject.Dispose()
at Umbraco.Core.Services.ContentService.SaveAndPublishDo(IContent content, Int32 userId, Boolean raiseEvents)
at Umbraco.Core.Services.ContentService.Umbraco.Core.Services.IContentServiceOperations.SaveAndPublish(IContent content, Int32 userId, Boolean raiseEvents)
at Umbraco.Core.Services.ContentService.SaveAndPublishWithStatus(IContent content, Int32 userId, Boolean raiseEvents)
at Umbraco.Web.Editors.ContentController.PostSaveInternal(ContentItemSave contentItem, Func`2 saveMethod)
at lambda_method(Closure , Object , Object[] )
at System.Web.Http.Controllers.ReflectedHttpActionDescriptor.ActionExecutor.<>c__DisplayClass10.<GetExecutor>b__9(Object instance, Object[] methodParameters)
at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
at System.Web.Http.Controllers.ApiControllerActionInvoker.<InvokeActionAsyncCore>d__0.MoveNext()
at System.Web.Http.Filters.ActionFilterAttribute.<CallOnActionExecutedAsync>d__5.MoveNext()
at System.Web.Http.Filters.ActionFilterAttribute.<ExecuteActionFilterAsyncCore>d__0.MoveNext()
at System.Web.Http.Controllers.ActionFilterResult.<ExecuteAsync>d__2.MoveNext()
at System.Web.Http.Filters.AuthorizationFilterAttribute.<ExecuteAuthorizationFilterAsyncCore>d__2.MoveNext()
at System.Web.Http.Controllers.ExceptionFilterResult.<ExecuteAsync>d__0.MoveNext()
As far as I know you do not need to do a using of the Database object. Can access directly by placing in a variable.
public class EventHandler : IApplicationEventHandler
public void OnApplicationInitialized(UmbracoApplicationBase umbracoApplication, ApplicationContext applicationContext) { }
public void OnApplicationStarting(UmbracoApplicationBase umbracoApplication, ApplicationContext applicationContext) { }
public void OnApplicationStarted(UmbracoApplicationBase umbracoApplication, ApplicationContext applicationContext)
ContentService.Publishing += ContentServiceOnPublishing;
private void ContentServiceOnPublishing(IPublishingStrategy sender, PublishEventArgs<IContent> e)
var db = ApplicationContext.Current.DatabaseContext.Database;
var sql = new Sql().Select("*").From<TEntity>();
var result = db.Query<TEntity>(sql);
Sounds like you have a winning answer. Even though context is slightly different and wasn't using the exact same code from the code sample, it did get me in the right direction!
Accessing ApplicationContext.Current.DatabaseContext.Database in IApplicationEventHandler results in sql issues
Consider below piece of code:
which used to work fine pre v7.7.6, yet since upgrade to v7.7.6, results in sql issues (reported in log file)
Am I not supposed to use it anymore or is this a bug? Looks like a bug to me, unless someone convinces me otherwise!
Feedback appreciated!
--Dirk
Detailed error log:
Hi Dirk
Good work, Marcio, #h5yr
--Dirk
