  • Jakob Kristensen 36 posts 169 karma points
    Dec 18, 2017 @ 14:56
    Jakob Kristensen
    RTE Property not updating in custom section
    Hi guys/gals
    Im doing some custom sections and been happy with angular, however some of the buildin property editors for umbraco is really hard to figure out!
    Currently i have an RTE i want to reuse, my code is like so:
    Editor
                     <umb-property property="property"
                                      ng-repeat="property in rteProperties">
                            <umb-editor model="property"></umb-editor>
                        </umb-property>
    JS:
     $scope.text = "";
     $scope.rteProperties = [{
                    label: 'label',
                    description: 'desc',
                    view: 'rte',
                    value: $scope.text,
                    config: {
                        editor: {
                            readonly: true,
                            toolbar: [],
                            stylesheets: [],
                            dimensions: { height: 400 }
    Can you give me some pointers why the text in $scope.text is not updating when updating the tinymce editor ?
  • Markus Johansson 1945 posts 5899 karma points MVP 2x c-trib
    Dec 18, 2017 @ 15:14
    Markus Johansson
    Hi!
    You can't set the value to a variable as it's already a variable.
    Basiclly the value of the RTE in your case will be stored in $scope.rteProperties.value - if you need a initial value you would set that like this:
    $scope.rteProperties.value = 'This is my initial value'
    Then when you want to store it / read the value
    var myRteValue = $scope.rteProperties.value
    I wrote a blog post about this some years ago but it should still be relevant: http://www.enkelmedia.se/blogg/2013/12/4/umbraco-7-use-the-rich-text-editor-tinymce-in-a-custom-section.aspx
    Hope this helps!
    Dec 18, 2017 @ 20:07
    Jakob Kristensen
    Hello Markus
    Thank you for the answer, i was using that blog earlier where this was one of the options, really appreciate the effort!
    I was thinking in knockout mode where one would make a binding for an editor and pass in the observable to use.
    The answer ended up being $scope.rteProperties[0].value that returned the correct value.
    Thank you for the help, still new to these custom sections but they are growing on me, angular is very powerful :)
    Dec 19, 2017 @ 11:11
    Markus Johansson
    Great news =D
    Yes, your right! $scope.rteProperties[0].value is the why to go =D Forgot about the array.
    Cheers!
    // m
