  • charlie black 33 posts 106 karma points
    Dec 20, 2017 @ 23:25
    charlie black
    running umbraco from within asp.net mvc web app without web.config roleManager
    We developed a asp.net mvc app that run "over" umbraco - our day-to-day users should not know umbraco is there. We originally developed this with umbraco 4.7 ( and are now in the process of upgrading to 7.5.6). The
    System.Configuration.Provider.ProviderException: The Role Manager feature has not been enabled. STACKTRACE
    at System.Web.Security.Roles.EnsureEnabled() at System.Web.Security.Roles.getProvider() at umbraco.cms.businesslogic.member.Member.IsUsingUmbracoRoles() at umbraco.loadMemberGroups.CreateRootNode(XmlTreeNode& rootNode) at umbraco.cms.presentation.Trees.BaseTree.CreateRootNode() at umbraco.cms.presentation.Trees.BaseTree.Initialize() at umbraco.cms.presentation.Trees.BaseTree.getRootNode() at Umbraco.Web.Trees.ApplicationTreeExtensions.TryGetRootXmlNodeFromLegacyTree(ApplicationTree appTree, FormDataCollection formCollection, UrlHelper urlHelper) at Umbraco.Web.Trees.ApplicationTreeExtensions.TryGetRootNodeFromLegacyTree(ApplicationTree appTree, FormDataCollection formCollection, UrlHelper urlHelper, String currentSection) at Umbraco.Web.Trees.ApplicationTreeController.
    In version 7.5.6, you now see this exception in a small window displayed on the right-hand side.
    You can still just ignore it and go on. THe alternatives are to put the
  • Damiaan 442 posts 1302 karma points MVP 6x c-trib
    Dec 21, 2017 @ 15:57
    Damiaan
    The preferred way, and what we would do is implement a custom MembershipProvider and RoleProvider which connects to you own system to handle users.
    Alternatively, (and a wild guess) because your exception contains a "ApplicationTreeController" I guess you still have the section in your applications. Just remove the application and the trees from your config files.
    Hope it helps Kind regards
    Dec 21, 2017 @ 17:08
    charlie black
    Damiaan-
    I am not that knowledgable about configuring umbraco, but I think I removed the add alias="member ... from applications.config but when I restart our app and (eventually log back in to the backoffice ) some process has magically restored that add alias="member" node.
    Is this what you mean by "Just remove the application...from your config files."
    Can you point out what I am doing wrong?
    I would really appreciate it.
    Dec 22, 2017 @ 00:18
    charlie black
    Seems like you have to go into the umbraco db, and find all rows in the table umbracoUser2app with app = 'member' and remove them. If you do that, then umbraco will be sure to keep that section hidden when you log into backoffice.
