Authenticating custom Umbraco controller with OWIN/OIDC against Azure AD B2C
I am stuck.
I have a custom Umbraco controller which inherits from RenderMvcController and when the Index() action method is hit a file is returned. This works, but what I want to do is to protect it by decorating the action with an AuthorizeAttribute and then requiring the user to authenticate.
namespace MyNamespace.Controllers
public class MyModelController : RenderMvcController
[Authorize]
public ActionResult Index(RenderModel model)
The authentication is to be made using OWIN and OpenId Connect against an Azure AD B2C app. This also works and is tested, but in a non-Umbraco context.
I have read numerous threads and code relating to the subject, but I am struggling to integrate it within Umbraco. I have a custom startup class which inherits from UmbracoDefaultOwinStartup. I register a custom route to my AuthController and configure OIDC via IAppBuilder.UseOpenIdConnectAuthentication().
But I need the Umbraco glue and have problems understanding how I should configure the cookies. I have checked that the startup Configuration() method is invoked.
public class CustomOwinStartup : UmbracoDefaultOwinStartup
public override void Configuration(IAppBuilder app)
base.Configuration(app);
ConfigureAuth(app);
RouteTable.Routes.MapRoute(
"CustomAuth",
"CustomAuth/{action}",
new { controller = "Auth" }
private void ConfigureAuth(IAppBuilder app)
app.SetDefaultSignInAsAuthenticationType(CookieAuthenticationDefaults.AuthenticationType);
app.UseCookieAuthentication(new CookieAuthenticationOptions
AuthenticationType = DefaultAuthenticationTypes.ApplicationCookie,
LoginPath = new PathString("/CustomAuth/SignUpSignIn") // TODO: What should I put here?
app.UseExternalSignInCookie(DefaultAuthenticationTypes.ExternalCookie);
app.UseOpenIdConnectAuthentication(
// Passing options that are tested and working
And then I have my auth controller which is very simple for the time being. I have no requirement to sync the auth info with Umbraco users.
public partial class CustomAuthController : Controller
public CustomAuthController() : base()
public void SignUpSignIn()
if (!Request.IsAuthenticated)
HttpContext.GetOwinContext().Authentication.Challenge();
return;
Response.Redirect("/"); // TODO: Maybe this should redirect me back to original route MyModel/Index in some way
If I run this and try to via my attribute-decorated custom Umbraco controller I get this error:
Page not found
No umbraco document matches the url '/login.aspx?ReturnUrl=MYORIGINALROUTEHTTPENCODED'.
This page can be replaced with a custom 404. Check the documentation for "custom 404".
My guess is that this is because of the <authentication mode="Forms"> setting in Web.config, but if I remove this or set the attribute mode to "None", will this not impact the back-office login?
Very thankful if anyone can help me point me in the right direction!
I am stuck.
RenderMvcControllerand when theIndex()action method is hit a file is returned. This works, but what I want to do is to protect it by decorating the action with anAuthorizeAttributeand then requiring the user to authenticate.The authentication is to be made using OWIN and OpenId Connect against an Azure AD B2C app. This also works and is tested, but in a non-Umbraco context.
UmbracoDefaultOwinStartup. I register a custom route to myAuthControllerand configure OIDC viaIAppBuilder.UseOpenIdConnectAuthentication().But I need the Umbraco glue and have problems understanding how I should configure the cookies. I have checked that the startup
Configuration()method is invoked.And then I have my auth controller which is very simple for the time being. I have no requirement to sync the auth info with Umbraco users.
<authentication mode="Forms">setting inWeb.config, but if I remove this or set the attributemodeto"None", will this not impact the back-office login?Very thankful if anyone can help me point me in the right direction!
