  • Mark Edison Khu 3 posts 72 karma points
    Jan 15, 2018 @ 04:38
    Mark Edison Khu
    Applying custom filter for backoffice listview
    We are doing a simple seminar registration in our website using umbraco. I just wanted to seek for help on how to create a custom filter using the backoffice list view? Are there any resources you can give for me to use?
    enter image description here Attached is the screenshot of our page, and we want to filter the list based on the seminar or seminar date attended.
    Thank you!
  • Dan Diplo 1554 posts 6205 karma points MVP 6x c-trib
    Jan 15, 2018 @ 13:00
    Dan Diplo
    You can create a custom list view layout, though it's not that simple. The best two resources I know are:
    https://24days.in/umbraco-cms/2016/custom-list-view-layouts/
    https://umbraco.tv/videos/umbraco-v7/developer/extending/custom-listview/
    Good luck!
    Jan 16, 2018 @ 02:29
    Mark Edison Khu
    Hello, thank you for your reply sir. It seems that there is no easy way to implement custom filter. I'll just use your diploaudit plugin as a reference and the links you've shared. I hope that Umbraco can implement custom filters in the future.
    Thank you!
  • Andy Felton 185 posts 484 karma points c-trib
    Mar 31, 2020 @ 13:49
    Andy Felton
    Hi Mark,
    Did you manage to complete the filter for list view? I'm currently seeing no way to filter the paged list of items passed to the List View controller and reducing the number of pages?
    Andy
  • Francis Benyah 35 posts 112 karma points
    Apr 16, 2020 @ 08:33
    Francis Benyah
    Hi Mark, Andy
    Did you guys figure out a way of doing this without changing the core?
    Seems I also need to find a similar solution.
    In my case though it is a little bit more complex as I need to search based on a content picker property.
    I tried to use Nexu (https://our.umbraco.com/packages/backoffice-extensions/nexu/) in the interim but I think the number of nodes might be killing it so it doesn't seem to finish building its index for the nodes with a ton of children
    Apr 16, 2020 @ 08:42
    Andy Felton
    Hi Francis,
    No sorry I got to the point where this would need a change to the core to get it working.
    Thanks Andy
    Apr 16, 2020 @ 09:30
    Francis Benyah
    Thanks Andy
    I am also sitting with the same dilema at the moment and trying to avoid going that route.
    If I make any positive progress will let you know.
  • Tim 68 posts 91 karma points
    Jul 03, 2023 @ 10:25
    Tim
    Did anyone get this working? I'd like to do something like this...
  • Obi Onuorah 3 posts 73 karma points
    Oct 17, 2023 @ 06:42
    Obi Onuorah
    @Tim did you get anywhere with your implementation? Why are the umbraco team silent about this? I have asked and somehow the question always gets sidestepped
    Nov 14, 2023 @ 17:22
    Tim
    Hey Obi,
    Nope, and now I have another task that would work really benefit from having custom filters in a list view.
    Umbraco team, could do better...
    Oct 17, 2023 @ 07:57
    Marc Goodson
    Hi Obi
    Is there a ticket on the issue tracker for this?
    https://github.com/umbraco/Umbraco-CMS/issues
    Can try to see if there are any plans afoot for a ListView 2.0...
    In past I've gone one of two ways with this kind of dilemma... either hijack the Search:
    https://dev.to/skttl/how-to-customize-searching-in-umbraco-list-views-1knk
    and enable 'special' search terms, eg if editor types colour:blue - then the custom implementation of search, detects this, and only searches for List View Items with the specific colour
    or
    I've just created my own Custom Dashboard to give a UI dedicated to filtering results.
    But be great if there was a mechanism to customise the ListView filter UI built in.
    regards
    Marc
