  • Dave Hobbs 2 posts 83 karma points
    Jan 18, 2018 @ 11:15
    Dave Hobbs
    Using Autofac - how to inject / use DatabaseContext
    I've started using Autofac and separated my "services" with the goal I can write unit tests. Some services need to access custom DB tables. What's the best practice for accessing / using the Umbraco DBContext?
    I have something like: enter image description here
    But obviously that's not going to be right for unit tests? Do I need some kind of factory / wrapper. Does anyone have any examples of how to do this?
    Thanks in advance, Dave
  • Tom Steer 161 posts 596 karma points
    Jan 18, 2018 @ 13:13
    Tom Steer
    Hi Dave,
    You should just need to register the DatabaseContext with Autofac container and then put it as a parameter to your constructor.
    builder.Register(ctx => ApplicationContext.Current.DatabaseContext).ExternallyOwned();
    Tom
    Jan 19, 2018 @ 11:38
    Dave Hobbs
    Hi Tom,
    Brilliant - thanks! That seems to work though I'll confess I'm lost how it's injecting it!
    To anyone who finds themselves here it just then needed injecting as
    public ClientsDataRepository(DatabaseContext databaseContext)
                //todo: this is not great?! needs a wrapper so I can inject it?
                //_db = ApplicationContext.Current.DatabaseContext.Database;
                _db = databaseContext.Database;
  • Martin Griffiths 826 posts 1269 karma points c-trib
    Dec 30, 2020 @ 14:22
    Martin Griffiths
    Hi Dave
    Can you provide a little more context into how you used this?
    Martin
