  • Craig O'Mahony 364 posts 918 karma points
    Jan 18, 2018 @ 15:55
    Craig O'Mahony
    Render related links contained in Archetype 'section'
    Hi folks.
    I'm having trouble rendering a Related Links picker that's found in an Archetype section.
    To further explain I've got a Archetype with three properties, 2 textstrings and a related links picker. I can get the string values no problem but I cannot get the related links.
    What I've got so far is:
    var linksNode = new umbraco.NodeFactory.Node(dNode.Id);
    var links = JsonConvert.DeserializeObject<ArchetypeModel>(linksNode.GetProperty("drawerSection").Value);
    foreach (var link in links)
        <p>@link.GetValue("drawerColumns")</p> //displays fine
        <p>@link.GetValue("drawerTitle")</p> //displays fine
    If I use @link.Getvalue("drawerLinks") I see an enormous string that contained all of the related link data but try as I might I can't get 'inside' it to loop through all of the links.
    Any advice would be greatly received.
    Thanks, C
    Jan 18, 2018 @ 20:52
    Alex Skrypnyk
    Hi Craig
    You have to parse related links json for rendering it, try this code
    var array = JArray.Parse(link.GetValue("drawerLinks"));
    <ul>
                @foreach (var item in array)
                    var linkUrl = (item.Value<bool>("isInternal")) ? Umbraco.NiceUrl(item.Value<int>("internal")) : item.Value<string>("link");
                    var linkTarget = item.Value<bool>("newWindow") ? "_blank" : null;
                    <li><a href="@linkUrl" target="@linkTarget">@(item.Value<string>("caption"))</a></li>
    </ul>
    Jan 19, 2018 @ 09:13
    Craig O'Mahony
    Hi Alex,
    Fantastic! I'm getting some errors on the linkUrl and linkTarget but I think that is down to the UDI / ID change in Umbraco.
    Thanks again, Craig
    Jan 19, 2018 @ 09:26
    Alex Skrypnyk
    Hi Craig
    What error? Lets have a look together
    Jan 19, 2018 @ 09:40
    Craig O'Mahony
    Hiya,
    The error is:
    'item.Value
    System.FormatException: 'Input string was not in a correct format.'
    item = {{ "caption": "Anti money Laundering", "link": "umb://document/a2fb93c35b6342548332aa130ea01ac0", "newWindow": false, "internal": "umb://document/a2fb93c35b6342548332aa130ea01ac0", "edit": false, "isInternal": true, "internalName": "UK"...
    These are the values contained within the item
    I'm resuming that I need to convert this UDI into an ID in order to be able to use the NiceUrl.
    Thanks, Craig
    Jan 19, 2018 @ 09:48
    Alex Skrypnyk
    Hi Craig
    Try this line:
    var linkUrl = (item.Value<bool>("isInternal")) ? Umbraco.TypedContent(Udi.Parse(item.Value<string>("internal"))).Url : Umbraco.TypedContent(Udi.Parse(item.Value<string>("link"))).Url;
    Jan 19, 2018 @ 10:02
    Craig O'Mahony
    Good work!
    Just had to change the external link clause as obviously Umbraco doesn't know what www.imdb.com is!
    var linkUrl = (item.Value<bool>("isInternal")) ? Umbraco.TypedContent(Udi.Parse(item.Value<string>("internal"))).Url : item.Value<string>("link");
    Thanks for your time and assistance :)
    Thanks, C
