  • Graham 4 posts 94 karma points
    Jan 24, 2018 @ 11:54
    Graham
    Property Editor Settings example not working?
    Hello, I'm new to Umbraco and to Angular, so apologies if this is a stupid question.
    I have followed the video tutorials on umbraco.tv, and am currently adding settings to a property editor: https://umbraco.tv/videos/umbraco-v7/developer/extending/property-editors/using-services/
    The code was working fine when I hard coded a character limit, but as soon as I introduce the $scope.model.config.limit, it stops working (if I look at $scope.model.config in Chrome inspector, it just says "Object", and there is no limit property).
    I can see that my limit property is there when I edit the datatype (/developer/dataTypes/edit/id), but it is not there when editing the content itself.
    I've been scratching my head (and banging it against my desk) for a while now.
    I found the download for the source code, and copied / pasted it over my own work. I also made sure my cache is cleared and application fully restarted by changing web.config. I'm not sure if it is relevant, but I am debugging through Visual Studio 2015, and I am using the latest version of Umbraco (7.7.8). I have the same problem in Chome and Firefox.
    The code, as I say, is a direct copy of what is available from the website, but for info, here it is:
    charlimit.controller.js:
    angular.module("umbraco").controller("Example.CharLimitController", function ($scope) {
        $scope.limitchars = function () {
            var limit = $scope.model.config.limit;
            if ($scope.model.value.length > limit) {
                $scope.info = 'You cannot write more then ' + limit + ' characters!';
                $scope.model.value = $scope.model.value.substr(0, limit);
            else {
                $scope.info = 'You have ' + (limit - $scope.model.value.length) + ' characters left.';
    charlimit.editor.html:
    <div ng-controller="Example.CharLimitController">
        <textarea cols="10" ng-model="model.value" ng-change="limitchars()"></textarea>
        <br />
        <span ng-bind="info"></span>
    package.manifest:
        propertyEditors: [
                alias: "CharLimit",
                editor: {
                    view: "~/App_Plugins/Example/charlimit.editor.html"
                prevalues: {
                    fields: [
                            label : "Number of chars",
                            description: "The number of characters to limit on",
                            key: "limit",
                            view: "number"
        javascript: [
            "~/App_Plugins/Example/charlimit.controller.js"
  • Alex Skrypnyk 6181 posts 24242 karma points MVP 8x admin c-trib
    Jan 24, 2018 @ 12:22
    Alex Skrypnyk
    Hi Graham
    What you added property editor to the document type, did you set value for a limit configuration?
    You can do it in the add property to the docType, please, have a look at this gif:
    Alex
    Jan 24, 2018 @ 12:27
    Graham
    Aha! Thank you so much.
    So, what is the purpose of the setting that I did set then? The one in umbraco#/developer/dataTypes/edit/
    Is that just a red herring? Surely not?
    Jan 24, 2018 @ 12:29
    Alex Skrypnyk
    The purpose of the setting that is that you can specify property editor configuration for each document type.
    If you need the same configuration for all document Type - use default configuration - https://our.umbraco.org/documentation/extending/property-editors/package-manifest#default-config
    /Alex
