  • Streety 358 posts 568 karma points
    Jan 25, 2018 @ 18:06
    Streety
    Custom Treenodes not being styled correctly.
    When selecting my custom treenode, the selected node is not being highlighted (styled with a different backcolour as is Umbraco default). enter image description here
    In the picture (above) the Strava Mass Emailer object is selected. The correct route and html is shown, but the tree item is not highlighted.
    However when I "navigationService.syncTree" after I create a new child node, this DOES get the styling class. However clicking another node doesn't remove the styling.
    It looks like the class in question is :
    .umb-tree li.current>div a
    If I select one of my nodes, it is not getting the ".current" classname appended and thus not applying the style.
    Is this a bug?
    Feb 01, 2018 @ 09:43
    Streety
    Bueller!
  • Liebherr574 1 post 71 karma points
    Feb 08, 2018 @ 11:25
    Liebherr574
    With Umbraco 7.5
    in my case (display webform page), i use on Page_load :
     new Umbraco.Web.UI.Pages.ClientTools(this).SyncTree(Request.QueryString["path"],false);
    or in Js
    UmbClientMgr.mainTree().syncTree(path, false);
    I make Path in GetTreeNodes(string id, FormDataCollection queryStrings)
    TreeNode TrNode = CreateTreeNode(Chapter.Id.ToString(), id, queryStrings, Chapter.Name, "icon-utilities", HashChild);
    TrNode.Path = id + "," + Chapter.Id; // easy for two level
    Path is passed to display Page in URL
    string.Format("/umbraco/Views/MyCustomApp/Read.aspx?id={0}&path={1}", Chapter.Id, TrNode.Path)
    Feb 08, 2018 @ 12:11
    Streety
    Hmmm, Thanks for that...
    I am not sure we are talking about the same things, my treenodes work just fine.
    However the class .current is not being appended to the current li. I suspect this is a function beyond our control.
    If I could get access to the node JS I could toggle the class, but the tree is dynamically created
