I have already setup Umbraco in Visual Studio and installed via Nuget. I like what I have seen! I would like to now get the source code running for multiple reasons. I have pulled the source from Git Hub and followed the instructions. (https://github.com/umbraco/Umbraco-CMS/blob/dev-v7.8/BUILD.md) The PowerShell Script has finished successfully (several times).
I checked the logs and I do see some errors in the Belle setup log files (see below).
I'm guessing the fact that Belle had issues installing, that is the reason why
in the IsConfigured flag in the Web Project InstallController is set to false when I debug....
if (ApplicationContext.Current.IsConfigured) //Always False
return Redirect(SystemDirectories.Umbraco.EnsureEndsWith('/'));
Belle.tmp Log File
npm
ERR!
node install.js
npm
ERR!
You can get information on how to open an issue for this project with:
npm
ERR!
npm bugs phantomjs-prebuilt
npm
ERR!
Or if that isn't available, you can get their info via:
npm
ERR!
npm owner ls phantomjs-prebuilt
npm
ERR!
There is likely additional logging output above.
npm
ERR!
Please include the following file with any support request:
executing gulp build for version @{Semver=7.7.10; Release=7.7.10; Comment=; Build=}
[20:56:39] Using gulpfile D:\Source\UmbracoCMS\Umbraco-CMS\src\Umbraco.Web.UI.Client\gulpfile.js
[20:56:39] Starting 'build'...
[20:56:39] Starting 'dependencies'...
[20:56:39] Starting 'js'...
[20:56:39] Starting 'less'...
[20:56:39] Starting 'views'...
copying src/views//html to ../Umbraco.Web.UI/Umbraco/views/
copying src/canvasdesigner//.html to ../Umbraco.Web.UI/Umbraco/views/../preview
copying src/installer/steps/*.html to ../Umbraco.Web.UI/Umbraco/views/install
[20:56:44] Finished 'less' after 5.04 s
[20:56:46] Finished 'js' after 7.52 s
[20:56:48] Finished 'views' after 9.22 s
[20:56:50] Finished 'dependencies' after 12 s
[20:56:50] Starting 'test:unit'...
[31m14 02 2018 20:56:50.761:ERROR [plugin]: [39mCannot find plugin "karma-phantomjs-launcher".
Did you forget to install it?
npm install karma-phantomjs-launcher --save-dev
[20:56:50] Finished 'test:unit' after 38 ms
[20:56:50] Finished 'build' after 12 s
[33m14 02 2018 20:56:50.795:WARN [watcher]: [39mPattern "D:/Source/UmbracoCMS/Umbraco-CMS/src/Umbraco.Web.UI.Client/lib-bower/jquery/jquery.min.js" does not match any file.
[33m14 02 2018 20:56:50.796:WARN [watcher]: [39mPattern "D:/Source/UmbracoCMS/Umbraco-CMS/src/Umbraco.Web.UI.Client/lib-bower/underscore/underscore-min.js" does not match any file.
[33m14 02 2018 20:56:50.796:WARN [watcher]: [39mPattern "D:/Source/UmbracoCMS/Umbraco-CMS/src/Umbraco.Web.UI.Client/lib-bower/moment/moment-with-locales.js" does not match any file.
[33m14 02 2018 20:56:50.796:WARN [watcher]: [39mPattern "D:/Source/UmbracoCMS/Umbraco-CMS/src/Umbraco.Web.UI.Client/lib-bower/rgrove-lazyload/lazyload.js" does not match any file.
[33m14 02 2018 20:56:50.796:WARN [watcher]: [39mPattern "D:/Source/UmbracoCMS/Umbraco-CMS/src/Umbraco.Web.UI.Client/lib-bower/angular-local-storage/angular-local-storage.min.js" does not match any file.
[31m14 02 2018 20:56:50.946:ERROR [karma]: [39mFound 1 load error
Hi there Caleb, it seems like you're interested in contributing to Umbraco, which is great!
I couldn't figure out exactly what was exactly what the problem is. I can't remember exactly what you will see when building belle but is there something actually wrong after you run the project?
The IsConfigured flag will be false untill you install Umbraco after you run it from source.
You write that you have many reasons you need to run from source. In our opinion there is only TWO ever reasons to run from source and those are:
to step through the debugger for fine-grained debugging
to contribute to umbraco fixing outstanding bugs and feature requests and submitting them back to us
If you don't know: Umbraco has loads and loads of extension points and you can achieve whatever you need to achieve without recompiling the source. When you do run a custom build that immediately guarantees you will never be able to upgrade Umbraco and you don't benefit from bug fixes and security updates in the future.
I thought running the build.ps1 powershell would take care of the install and get me past this, but that doesn't seem to be the case for me.
Fine grained debugging is the number 1 reason why I want to run the source code, 2nd would be submitting back any bugs that we find. 3rd is knowing what is going on behind the scenes before we go to production. 4th is knowing we can do something with the source code if we need to.
I agree as I'm learning the extending Umbraco is great, and we should always capitalize on that first!
Lastly the reason I'm trying is because when we are calling the Umbraco rest api we keep getting unauthorized request, even though we call the token endpoint successfully and get a token. I wanted to see if debugging I could figure out why.
You can't get past AuthorizeUpgrade because you can't login as Umbraco has not been set up yet. I think you need to clear the umbraco version in web.config:
This will kick in the installer to install a new instance of Umbraco. If there's a ~/App_Data/Umbraco.sdf file then delete that one as well.
Just FYI:
In our experience, people just starting out with Umbraco should not try to dive into the source code right away. It will probably lead to more confusion than clarification. The code base for many part is old and convoluted and we're slowly working on detangling everything in the upcoming v8. It's often more productive to ask questions on the forum.
Running from Source Code
I'm guessing the fact that Belle had issues installing, that is the reason why in the IsConfigured flag in the Web Project InstallController is set to false when I debug.... if (ApplicationContext.Current.IsConfigured) //Always False { return Redirect(SystemDirectories.Umbraco.EnsureEndsWith('/'));
Belle.tmp Log File npm
ERR! node install.js
npm
ERR! You can get information on how to open an issue for this project with:
npm
ERR! npm bugs phantomjs-prebuilt
npm
ERR! Or if that isn't available, you can get their info via:
npm
ERR! npm owner ls phantomjs-prebuilt
npm ERR! There is likely additional logging output above.
npm
ERR! Please include the following file with any support request:
npm
ERR! D:\Source\UmbracoCMS\Umbraco-CMS\src\Umbraco.Web.UI.Client\npm-debug.log
executing gulp build for version @{Semver=7.7.10; Release=7.7.10; Comment=; Build=} [20:56:39] Using gulpfile D:\Source\UmbracoCMS\Umbraco-CMS\src\Umbraco.Web.UI.Client\gulpfile.js [20:56:39] Starting 'build'... [20:56:39] Starting 'dependencies'... [20:56:39] Starting 'js'... [20:56:39] Starting 'less'... [20:56:39] Starting 'views'... copying src/views//html to ../Umbraco.Web.UI/Umbraco/views/ copying src/canvasdesigner//.html to ../Umbraco.Web.UI/Umbraco/views/../preview copying src/installer/steps/*.html to ../Umbraco.Web.UI/Umbraco/views/install [20:56:44] Finished 'less' after 5.04 s [20:56:46] Finished 'js' after 7.52 s [20:56:48] Finished 'views' after 9.22 s [20:56:50] Finished 'dependencies' after 12 s [20:56:50] Starting 'test:unit'... [31m14 02 2018 20:56:50.761:ERROR [plugin]: [39mCannot find plugin "karma-phantomjs-launcher". Did you forget to install it? npm install karma-phantomjs-launcher --save-dev [20:56:50] Finished 'test:unit' after 38 ms [20:56:50] Finished 'build' after 12 s [33m14 02 2018 20:56:50.795:WARN [watcher]: [39mPattern "D:/Source/UmbracoCMS/Umbraco-CMS/src/Umbraco.Web.UI.Client/lib-bower/jquery/jquery.min.js" does not match any file. [33m14 02 2018 20:56:50.796:WARN [watcher]: [39mPattern "D:/Source/UmbracoCMS/Umbraco-CMS/src/Umbraco.Web.UI.Client/lib-bower/underscore/underscore-min.js" does not match any file. [33m14 02 2018 20:56:50.796:WARN [watcher]: [39mPattern "D:/Source/UmbracoCMS/Umbraco-CMS/src/Umbraco.Web.UI.Client/lib-bower/moment/moment-with-locales.js" does not match any file. [33m14 02 2018 20:56:50.796:WARN [watcher]: [39mPattern "D:/Source/UmbracoCMS/Umbraco-CMS/src/Umbraco.Web.UI.Client/lib-bower/rgrove-lazyload/lazyload.js" does not match any file. [33m14 02 2018 20:56:50.796:WARN [watcher]: [39mPattern "D:/Source/UmbracoCMS/Umbraco-CMS/src/Umbraco.Web.UI.Client/lib-bower/angular-local-storage/angular-local-storage.min.js" does not match any file. [31m14 02 2018 20:56:50.946:ERROR [karma]: [39mFound 1 load error
The
IsConfiguredflag will be false untill you install Umbraco after you run it from source.You write that you have many reasons you need to run from source. In our opinion there is only TWO ever reasons to run from source and those are:
So I'm curious what your other reasons are? ;-)
Hi Sebastiaan,
After I run the project I'm stuck here: http://localhost:7710/umbraco/AuthorizeUpgrade?redir=%2finstall%2f%3fredir%3dtrue%26url%3dhttp%253a%252f%252flocalhost%253a7710%252f
It always redirects here.
Just FYI, Rest API seems to be broken for now 7.8: https://github.com/umbraco/UmbracoRestApi/issues/42
<add key="umbracoConfigurationStatus" value="" />and the connection string:
<add name="umbracoDbDSN" connectionString="server=" providerName="" />This will kick in the installer to install a new instance of Umbraco. If there's a
~/App_Data/Umbraco.sdffile then delete that one as well.Just FYI: In our experience, people just starting out with Umbraco should not try to dive into the source code right away. It will probably lead to more confusion than clarification. The code base for many part is old and convoluted and we're slowly working on detangling everything in the upcoming v8. It's often more productive to ask questions on the forum.
Awesome, thanks for the quick responses. I will definitely be using the forum more.
Reverting back on the Rest API (the link you provided) solved our issue.
I will be testing out your suggestion on the source code as soon as I have some time.
Updated web.config
still stuck on the install, any other suggestions?
We are moving forward with using the Nuget packages in another solution, however I would still like to get this to run. :)
