"The input is not a valid Base-64 string" when calling Members.Login
Hi.
I'm trying to log our members in using the following code
Members.Login("jurian360", "password");
However this keeps throwing the following error:
The input is not a valid Base-64 string as it contains a non-base 64 character, more than two padding characters, or an illegal character among the padding characters.
I am running Umbraco version 7.7.7 assembly: 1.0.6554.23584.
Thanks, this was my exact issue as well!
Took a look at my created member in the backoffice and realised the "Last Password Change Date" property was empty.
I too came across this problem today. To add to the above, this error will throw when the user doesn't have a password.
In my case, MemberService.SavePassword was correctly throwing an error (the password didn't meet criteria) so trying to login to this user threw the error.
Hi. I'm trying to log our members in using the following code
The only other similar thread I could find was http://issues.umbraco.org/issue/U4-10752 but did not provide a solution for us.
Looking forward to your help.
Check out the encryption options for Umbraco passwords. In the DB, you can either store passwords as "plain text" or "encrypted".
I believe "encrypted" stores them as a base-64 encoded URI (although there may be a hash involved, too).
A work-around might be to simply check that their password matches, then log them in manually:
Thanks for your input.
I've been able to narrow it down further: It seems to only be a problem when I assign the password in code
If I assign the password via the normal Umbraco back-end, I am able to log in fine.
Furthermore, I have tried assigning the password via .CreateWithIdentity. This gives the exact same result.
Ok. It seems this was just a logical error on my part. I was calling .SavePassword before I had saved the member. All seems ok now.
Ah. Thanks! This helped me solve the same issue.
Thanks, this was my exact issue as well! Took a look at my created member in the backoffice and realised the "Last Password Change Date" property was empty.
In my case,
MemberService.SavePasswordwas correctly throwing an error (the password didn't meet criteria) so trying to login to this user threw the error.is working on a reply...
