I don't believe you actually can, not directly anyway. However I would advise having a look at the Articulate git hub repository. Shannon provides articulate through a nuget package as well as an Umbraco package. The Nuget package provides a post install screen in the back office where you can "initialise" articulate which, as I understand it, creates the doc types and nodes etc.
for the doc types and nodes (which is just data) you can use a custom umbraco db migration to do this.
templates need to be deployed alongside your install
Nuget: How to create Umbraco Document Types or Templates or nodes during installation?
Hi, I already have a .nuspec file that install the package by copying files in Umbraco project dir.
But now I added a new feature that needs to create one document type, one template and two nodes during install.
How can I do that? I can change only the .nuspec file (how?) or I need to do something else (what?).
Thank you for the support
Hi Adriano,
Might point you in the right direction :-)
Nik
Thank you Nik. If I can not do it, I think I'll create my custom action so the users can create them from my package.
for the doc types and nodes (which is just data) you can use a custom umbraco db migration to do this. templates need to be deployed alongside your install
Thank you Phil
