1) How can I get the index to automatically rebuild when content is published on the master server? (ideally only content within a specific parent/of a specific type)
2) Once rebuilt, how can I get the index to propagate to the slave machines so that the newly-rebuilt index is updated on all of them?
The docs are all Azure-specific so it's difficult to tell what is necessary and what isn't for AWS EBS. I've seen a few references to "it just works", but unfortunately that's definitely not the case in my experience so far!
Custom Examine index with AWS flexible load balancing on EBS
Does anyone have an example of how to get this working?
I have a custom indexer, configured in
ExamineSettings.configlike this:a search provider
and an index set, in
ExamineIndex.configI then have a custom class which implements
ISimpleDataServiceto query the content and create custom items which are inserted into the Index.This all works fine when generating the index manually through the back-end Rebuild Index button, but I have no idea how to get this to propagate from the master machine to the slave machines (1 master, 1 slave at the moment in this setup https://aws.amazon.com/blogs/devops/run-umbraco-cms-with-flexible-load-balancing-on-aws/).
I believe I have two questions:
Any help would be greatly appreciated.
