After this if i make some changes in the master server, there are no updates happening for the slave servers. Please let me know if i miss anything here and let me know if you need any other details to resolve my query.
I enabled backoffice only in the master server and blocked the same for slave servers using reqrite rule.
I am using MYSQL 5+ version for the database, after the update in the master server i can see few exceptions in the umbraco log file related to DB updates.
I have placed umbracoApplicationUrl on master and slave servers in umbracosettings.config
Thanks for your response, i have gone through that link already and even after that i faced this issue. But now , I succesfully configured the load balancer set up for AWS EC2. I had to fix one issue with the MYSQL related to table name casing. After that it worked like a charm.
Will move the changes to Live and get back to you if i face any issue in there.
Umbraco Load Balancer set up using AWS EC2
Hello ,
I have configured the load balancing set up using the documentation provided in the following link https://our.umbraco.org/Documentation/Getting-Started/Setup/Server-Setup/Load-Balancing/flexible.
I have used master slave set up to configure it ,based on the documentation provided here https://our.umbraco.org/Documentation/Getting-Started/Setup/Server-Setup/Load-Balancing/flexible-advanced .
Thanks in advance.
Hi Vinod,
Don“t know if you have seen this blogpost from Amazon on how to setup -flexible load balancing on AWS
https://aws.amazon.com/blogs/devops/run-umbraco-cms-with-flexible-load-balancing-on-aws/
Hope this helps,
/Dennis
Hi Dennis,
Thanks, Vinod Nanduri.
