  • James C 17 posts 138 karma points
    Apr 05, 2018 @ 15:43
    James C
    ContentService.Unpublish listener does not pick up on scheduled unpublish
    I am using Umbraco v 7.7.9. I have a class that listens for the unpublished event firing and performs some actions when it does. It works perfectly when content nodes are manually unpublished however, when I set content for scheduled unpublish it is not picked up. Here's my code:
        protected override void ApplicationStarted(UmbracoApplicationBase umbracoApplication, ApplicationContext applicationContext)
            // Hook on to the content node unpublish event firing
            ContentService.UnPublished += ContentServiceUnPublished;
        private void ContentServiceUnPublished(IPublishingStrategy sender, PublishEventArgs<IContent> args)
            // Do something
    Should this be the case? And if it is, is there something else I can do to pick up scheduled unpublish?
    Thank you in advance.
    Apr 06, 2018 @ 09:24
    Dave Woestenborghs
    Hi James,
    Can you try to reproduce this on the latest version of Umbraco.
    If so you can create a issue on http://issues.umbraco.org
    Apr 06, 2018 @ 10:00
    James C
    Hi Dave,
    No problem, I'll try that tonight thanks.
