I'm trying to set up a simple Custom Property Editor that has an input coupled to the GoogleMaps API. If users begin to type an address, an autocomplete appears. If they select an address from the autocomplete, it fills out some values in seperate inputs below the autocomplete.
What's frustrating me is that I cannot get it to save to the database when clicking 'save and publish'. I'm using a local instance of Umbraco V7.
this is my html:
<div class="container" ng-controller="addressautocomplete.editorcontroller">
<div id="locationField">
<input id="autocomplete" placeholder="Enter your address" ng-model="model.value.address" width="100%" value="{{model.value.address}}"
onfocus="geolocate()" type="text" />
<br />
<table id="address">
<tr>
<td class="label">Street address</td>
<td class="slimField">
<input class="field" id="street_number" ng-model="model.value.streetNumber" value="{{model.value.streetNumber}}" />
</td>
<td class="wideField" colspan="2">
<input class="field" id="route" ng-model="model.value.route" value="{{model.value.route}}" />
</td>
</tr>
<tr>
<td class="label">City</td>
<!-- Note: Selection of address components in this example is typical.
You may need to adjust it for the locations relevant to your app. See
https://developers.google.com/maps/documentation/javascript/examples/places-autocomplete-addressform
<td class="wideField" colspan="3">
<input class="field" id="locality" ng-model="model.value.locality" value="{{model.value.locality}}" />
</td>
</tr>
<tr>
<td class="label">State</td>
<input class="field" ng-model="model.value.state"
id="administrative_area_level_1" value="{{model.value.state}}" />
</td>
<td class="label">Zip code</td>
<td class="wideField">
<input class="field" id="postal_code" ng-model="model.value.zipcode" value="{{model.value.zipcode}}" />
</td>
</tr>
<tr>
<td class="label">Country</td>
<input class="field" id="country" ng-model="model.value.country" value="{{model.value.country}}" />
</td>
</tr>
</table>
And here's my controller:
angular.module("umbraco")
.controller("addressautocomplete.editorcontroller", function ($scope, notificationsService) {
Anything I'm doing wrong? I looked over some tutorials for the custom property editor and this seems like the way to do it?
Note: The script that handles the Google API is in my template, I tried to get it to work over the controller, but failed miserably. So this was kind of a lazy fix
When looking at the database, in the table cmsPropertyData, the field dataNvarchar shows an array filled with null values like so:
null,
null,
null,
null,
null,
null
Does this mean it recognises the ng-model, but not it's value?
I get 2 exactly the same errors, one when the page has landed and one after clicking the save button
This is the error:
"Error parsing header X-XSS-Protection: 1; mode=block; report=https://www.google.com/appserve/security-bugs/log/youtube: insecure reporting URL for secure page at character position 22. The default protections will be applied."
I started from scratch and I'm now able to save values to the db, without using the GoogleMapsApi.
I noticed when input fields are manipulated from javascript, that the binding doesn't seem to notice that something has changed. As a consequence, it doesn't save a value. When I change the value manually, then it does save.
In my context: the address autocomplete fills out the address input fields automatically when clicked using javascript.
basically the same code as before, but with this javascript file added:
you can click an address from a drop down, which is filled with addresses from googlemapsApi, then select one, and it fills out your form automatically
function fillInAddress() {
// Get the place details from the autocomplete object.
var place = autocomplete.getPlace();
for (var component in componentForm) {
document.getElementById(component).value = '';
document.getElementById(component).disabled = false;
// Get each component of the address from the place details
// and fill the corresponding field on the form.
for (var i = 0; i < place.address_components.length; i++) {
var addressType = place.address_components[i].types[0];
if (componentForm[addressType]) {
var val = place.address_components[i][componentForm[addressType]];
document.getElementById(addressType).value = val;
Custom Property Editor properties not saved.
Hi all!
this is my html:
and lastly, my manifest:
Hi Bert,
first of all Welcome to the Umbraco Our Community!
Don't know it this is the issue but on all of your inputs you do a
ng-modeland avaluebinding.Try removing the value attribute to see if this works. The
ng-modelwill set the value of the input so no need for the value attribute.Hope this helps.
/Michaël
Thanks for your reply Michaël!
I removed the value binding, but no luck.
[ null, null, null, null, null, null ]
Hi Bert,
could you try to add the following to your package.manifest:
Hope this helps!
/Michaël
Hi Michaël
This was already added inside the "propertyEditors" category, the only thing that's different was the missing "valueType": "JSON".
I added this and still nothing.
Thanks for your help so far!
/Bert
Hi Bert,
yes forgot to mention about the part of
valueType.Do you get console errors?
Thanks!
/Michaël
Hi Michaël
This is the error:
It "looks" irrelevant to this problem though.
/Bert
Hi Bert,
can you try the following.
Remove the part of Google Maps and just add the input and textarea fields. Then add manually some values in it and hit save and publish.
Does that work?
Hope this helps!
/Michaël
Hi Michael
I removed everything and again no luck so far. No new errors either.
I tried to add the property editor to another page, and save there but also nothing. The only difference now is that it saves an empty array.
T
Thanks again for your suggestions!
Update from the situation:
Bert,
can you show us the code? Why use javascript and not Angularjs for setting the values of your input fields?
Thanks!
/Michaël
basically the same code as before, but with this javascript file added: you can click an address from a drop down, which is filled with addresses from googlemapsApi, then select one, and it fills out your form automatically
html:
controller:
manifest:
"propertyEditors": [ {
"name": "Address Autocomplete", "alias": "addressAutocomplete", "isParameterEditor": true, "icon": "icon-bird", "group": "Google", "editor": { "view": "/appplugins/AddressLookup/editor.html", "valueType": "JSON" } } ], "javascript": [ "/appplugins/AddressLookup/js/editor.controller.js", "/app_plugins/AddressLookup/js/addressLookup.js" ] }
googlemaps JS:
