  • Edgar Rasquin 326 posts 925 karma points
    May 14, 2018 @ 12:53
    Edgar Rasquin
    set culture using contentSevice
    Hi everyone,
    does somebody know whether it's possible to set the culture using the contentService?
    Currently I am doing something like this:
    // create content service
            var contentService = ApplicationContext.Current.Services.ContentService;
            //create unique name for umbraco
            var uniqueName = name + code;
            var newJobPost = contentService.CreateContentWithIdentity(uniqueName, 4483, "job");
            newJobPost.SetValue("betreff", name);
            newJobPost.SetValue("code", code);
            newJobPost.SetValue("location", location);
            //save & publish
            var status = contentService.SaveAndPublishWithStatus(newJobPost);
    That creates nodes with the the culture "inherit".
    Is there a way I can set a specific culture like "de" or "it"... ?
    Thanks a lot.
    Aug 01, 2018 @ 09:59
    Alex Skrypnyk
    Hi Edgar
    You need to set culture to thread like that:
    System.Threading.Thread.CurrentThread.CurrentUICulture = new System.Globalization.CultureInfo(cookieLingua);
    System.Threading.Thread.CurrentThread.CurrentCulture = new System.Globalization.CultureInfo(cookieLingua);
    Alex
    Aug 01, 2018 @ 10:02
    Edgar Rasquin
    Hi Alex,
    thank you very much for your help. Very much appreciated!
    Regards
  • Rivkiker 6 posts 27 karma points
    May 23, 2023 @ 08:08
    Rivkiker
    Can I update the culture of existing node?
