  • Adriano Fabri 469 posts 1633 karma points
    Jun 04, 2018 @ 11:58
    Adriano Fabri
    How to use the umbPagination directive
    Hi to all. I have big problems using the umbraco pagination directive.
    In my package have a table with the list of DB logs. Now I'm trying to to use the umbPagination directive to page this list.
    I followed the official guide founded at the following link (https://our.umbraco.org/apidocs/ui/#/api/umbraco.directives.directive:umbPagination).
    The result is that the page navigation buttons are correctly displayed but the log's list isn't paged. All logs are shown in the first page.
    What I wrong?
    This is my view:
    <table id="FHLogTable" class="table table-striped table-bordered table-hover">
        <thead>
            <tr>
                <th class="text-center">Id</th>
                <th class="text-center">Date</th>
            <tr>
        </thead>
        <tbody>
            <tr ng-click="openDetailsModal(logItem, filteredLogs)" ng-repeat="logItem in filteredLogs = (logs.ListDBLogs | filter:q) | orderBy:sortKey:reverse" current-page="vm.pagination.pageNumber">
                <td class="text-center">{{ logItem.LogId }}</td>
                <td class="text-center">{{ logItem.LogDate | date: 'dd/MM/yyyy HH:mm:ss' }}</td>
            <tr>
        </tbody>
        <tfoot>
            <tr>
                <td colspan="2">
                    <umb-pagination
                        ng-if="filteredLogs.length > 0 && !$scope.showLoader"
                        page-size="vm.pagination.pageSize"
                        page-number="vm.pagination.pageNumber"
                        total-pages="vm.pagination.totalPages"
                        on-next="vm.nextPage"
                        on-prev="vm.prevPage"
                        on-go-to-page="vm.goToPage">
                    </umb-pagination>
               </td>
           </tr>
       </tfoot>
    </table>
    With this code, the pagination buttons are correctly shown but the table is not paged.
    What can I do to show the logs as a paged list?
    Thanks Adriano
    Jun 14, 2018 @ 09:45
    Adriano Fabri
    I tried also to change the classic table as umb-table...but I have the same result
    <div class="umb-table">
        <div class="umb-table-head">
            <div class="umb-table-row">
                <div class="umb-table-cell">Id</div>
                <div class="umb-table-cell">Date</localize></div>
        <div class="umb-table-body">
            <div class="umb-table-row" ng-click="openDetailsModal(logItem, filteredLogs)" ng-repeat="logItem in filteredLogs = (logs.ListDBLogs | filter:q) | orderBy:sortKey:reverse" current-page="vm.pagination.pageNumber" style="font-size: 0.8rem;">
                <div class="umb-table-cell">{{ logItem.LogId }}</div>
                <div class="umb-table-cell">{{ logItem.LogDate | date: 'dd/MM/yyyy' }}<br />{{ logItem.LogDate | date: 'HH:mm:ss' }}</div>
    <div class="flex justify-center items-center">
        <umb-pagination
        </umb-pagination>
  • Dan Diplo 1554 posts 6205 karma points MVP 6x c-trib
    Jun 14, 2018 @ 11:03
    Dan Diplo
    There's an example of using it in my Audit Log Viewer package you may be able to find handy:
    https://github.com/DanDiplo/Umbraco.AuditLogViewer
    Examples
    Angular View
    Angular Controller
    C# Controller
    Jun 14, 2018 @ 12:54
    Adriano Fabri
    Thank you Dan, I saw your code but I don't understand what I'm doing wrong.
    It seems that my code is correct.
    I am going crazy!!!
    If I give you (tell me how) the actual angular controller and view, you can help me to understand where is the problem?
    Thank you
    Jun 14, 2018 @ 13:44
    Dan Diplo
    The actual pagination is done in the SQL, which uses the db.Page
    eg. db.Page<LogEntry>(request.PageNumber, request.ItemsPerPage, query);
    https://github.com/DanDiplo/Umbraco.AuditLogViewer/blob/master/Diplo.AuditLogViewer/Services/LogService.cs
    Jun 19, 2018 @ 12:19
    Adriano Fabri
    Wonderful...now the DB Logs viewer works like a charm :-) Thank you very much.
    Now I'm trying to do the same with the Trace logs viewer...but for now I have the right pagination's buttons, but the log list is not paged.
    I'm trying to use PagedResult...but it isn't working.
    I'm working to solve it.
