How to get HasProperty working when Unit testing umbraco IPublishedProperty?
How to mock umbraco content and its properties so I could get the correct value of the property and HasProperty bool value?
I'm trying to test such method:
var properties = [...] // properties collection
UmbProperties(properties, content, model);
The method content:
protected T UmbProperties(PropertyInfo[] properties, IPublishedContent content, T model)
foreach (PropertyInfo property in properties)
string umbracoPropertyName = Char.ToLowerInvariant(property.Name[0]) + property.Name.Substring(1);
bool umbracoHasProperty = content.HasProperty(umbracoPropertyName); // this returns System.NullReferenceException when testing
return model;
Currently in my test method I have:
public void For_GetPropertyValueOfType()
var contentStub = new Mock<IPublishedContent>();
var propertyStub = new Mock<IPublishedProperty>();
propertyStub.Setup(p => p.Value).Returns("property value");
contentStub.Setup(c => c.GetProperty("test", false)).Returns(propertyStub.Object);
var model = [...] // some model
var content = contentStub.Object;
obj.UmbProperties(properties, content, model);
content is set well and not null, but HasProperty returns an error:
System.NullReferenceException: 'Object reference not set to an instance of an object.'
How to get HasProperty working correctly when setting property in the test method?
I don't want to do this for example:
var propertyValue = content.GetPropertyValue<string>("test");
var hasProp = propertyValue != null;
because I'm checking for the property type later in UmbProperties.
And this doesn't work either:
var propertyValue = content.GetPropertyValue("test");
var hasProp1 = propertyValue != null; // this returns false as propertyValue comes null if I;m not using type conversion as above
Right, I didn't realise HasProperty() was an extension method.
You can't test extension methods, or do .Setup() on them.
You'll have to create a wrapper for this method which can be a pain.
If I were you I'd create an interface and class named "IPublishedContentWrapper" and then have a method called HasProperty. Then you can inject this interface into your method and call your new HasProperty method. You'll then have to mock it in your test. E.g.:
public class PublishedContentWrapper : IPublishedContentWrapper
public bool HasProperty(IPublishedContent node, string propertyName)
return node.HasProperty(propertyName);
Then inject IPublishedContentWrapper as _publishedContent and change the UmbProperties method to call _publishedContent.HasProperty:
HasPropertybool value?I'm trying to test such method:
The method content:
contentis set well and notnull, butHasPropertyreturns an error:How to get
HasPropertyworking correctly when setting property in the test method?I don't want to do this for example:
Since you're calling HasProperty in your method, wouldn't you need to mock it?
Something like
I'm getting error as well:
Then change the setup method to add the following:
Hopefully this will work...
Either way I know you can't mock extension methods and you typically create wrappers for them (as above).
Hi, thanks! I'll try it and come back here.
