I'm sure this is probably an easy one but I've tried my first code sample using Fluidity and decide to make it harder for myself and swap out the int Id (from the getting started doc) to a uniqueidentifier.
I used this to set the Guid but I keep getting an error thrown, as below.
Also haven't been able to get there yet but not sure this will work for editing as well as updating e.g. need to add a if (p.Id != null)
at Fluidity.Web.Trees.FluidityTreeController.GetTreeNode(String id, FormDataCollection queryStrings)
at lambdamethod(Closure , Object , Object[] )
at System.Web.Http.Controllers.ReflectedHttpActionDescriptor.ActionExecutor.<>cDisplayClass10.9(Object instance, Object[] methodParameters)
at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
at System.Web.Http.Controllers.ApiControllerActionInvoker._1.MoveNext()
Fluidity using Guid for Id instead of int
Also this is the url that get's set after Save which looks a bit weird: http://localhost:85/umbraco/#/database/fluidity/edit/location!00000000-0000-0000-0000-000000000000
