Is there a way to programmatically add categories to a blog post?
Hi guys
I've managed to create blog posts programmatically, I just can't find a way to set its categories. Any ideas how to go about this?
var articlesPostsNodeId = 1550;
var blogPostNodeId = 1559; // existing blog post
var blogPostNode = Umbraco.TypedContent(blogPostNodeId);
var categories = blogPostNode.GetPropertyValue("postCategories") as IEnumerable<IPublishedContent>; // just to see how existing categories look like
foreach (var post in blogPosts)
var newBlog = contentService.CreateContent(post.Title, articlesPostsNodeId, blogPostNode.DocumentTypeAlias, 0);
if (newBlog != null)
// Set values for the document
newBlog.SetValue("pageSummary", post.Title.ToNullSafeString());
newBlog.SetValue("bodyText", post.BodyText.ToNullSafeString());
newBlog.SetValue("postDate", post.PublishDate.ToNullSafeString());
newBlog.SetValue("postCategories", categories); // ### This line fails ###
if (contentService != null)
var result = contentService.SaveAndPublishWithStatus(newBlog, 0, true);
Its called Blog Category Page (alias: USNBlogCategoryPage).
The structure is:
> Articles (blog landing page)
> Categories (folder)
- Accountancy (blog category page)
- Business (blog category page)
- etc.
> Posts (folder)
> 2018 (folder)
> June (folder)
- My post (Standard blog post page)
When I create a blog post, I can add multiple categories to it using an Umbraco.MultiNodeTreePicker2 property that lists the pages in the Categories folder. Does that make any sense?
Hi guys
BTW I'm really liking Umbraco 7.10! Well done =)
What datatype are you using for categories?
The structure is:
Umbraco does't store IPublishedContent for a multinode treepicker but a comma seperated list of GuidUdi's. For example:
To get this string you can do something like:
And than this should work:
Please let me know if this works.
Ohhhh man you don't exist!
Thank you so much, it worked like a charm =)
No problem. Glad I can give back to the community ;P
