I'm using umbraco 7.11 core and store the media on azure storage + cdn.
everything is working fine saving and getting the images through the cdn
I have one problem when I delete an image I get error that the image is not existing, this is the relevant part from the log file
2018-07-23 12:34:48,103 [P11020/D31/T13] INFO Domain.Concrete.UmbMemberRepository - deleting image 2694
2018-07-23 12:34:48,103 [P11020/D31/T13] INFO Domain.Concrete.UmbMemberRepository - deleting image 79cddc0a-4093-4e38-a3aa-5e7d1acd5a42
2018-07-23 12:34:48,212 [P11020/D31/T13] ERROR Our.Umbraco.FileSystemProviders.Azure.AzureFileSystem - Blob not found
System.IO.DirectoryNotFoundException: Blob not found at '\media\1469'
AzureFileSystem
hi all,
2018-07-23 12:34:48,212 [P11020/D31/T13] ERROR Our.Umbraco.FileSystemProviders.Azure.AzureFileSystem - Blob not found System.IO.DirectoryNotFoundException: Blob not found at '\media\1469'
and this is the code
LogHelper.Info(typeof(UmbMemberRepository), "deleting image " + member.ProfileImage.ImageId.ToString());
var mediaToDelete = ApplicationContext.Current.Services.MediaService.GetById(member.ProfileImage.ImageId);
LogHelper.Info(typeof(UmbMemberRepository), "deleting image " + mediaToDelete?.Key ?? "no image"); ApplicationContext.Current.Services.MediaService.Delete(mediaToDelete);
why there is an attempt to get the image after it has deleted?
