  • Dan Evans 631 posts 1018 karma points
    Sep 10, 2018 @ 16:01
    Dan Evans
    Updating a property using ContentService.Published
    I want to update a document property after the page is published with a value from a 3rd party web service.
    When I use contentService.SaveAndPublishWithStatus i end up in an infinite loop.
    When I use contentService.Save(node, 0); it works fine but then the page is flagged as having unpublished changes and is greyed out to the user which is confusing for them.
    How can I set a property value, publish the page and not end up in an infinite loop?
    private void ContentServicePublished(IPublishingStrategy sender, PublishEventArgs<IContent> args, UmbracoHelper helper)
            foreach (var node in args.PublishedEntities)
                        if (node.ContentType.Alias == "mGProperty")
                            string retVal = AppLib.sendPropLinkUmbraco(node.Id, "publish");
                            node.SetValue("advertRef", retVal);
                            //contentService.SaveAndPublishWithStatus(node,0, false);
    Sep 10, 2018 @ 19:57
    Alex Skrypnyk
    2
    Hi Dan
    Try to use Publishing event, have a look at content service events - https://our.umbraco.com/documentation/reference/events/contentservice-events
    Alex
    Sep 12, 2018 @ 12:42
    Dan Evans
    As I understand it both Publishing and Published both ignore the "raiseEvents" flag and both end up in an infinite loop so not a solution sadly.
  • Frans de Jong 550 posts 1862 karma points MVP 5x c-trib
    Sep 12, 2018 @ 14:39
    Frans de Jong
    You don't need to save the content at least when you are using ContentSerice.Saving.
    for example:
     protected override void ApplicationStarted(UmbracoApplicationBase umbracoApplication, ApplicationContext applicationContext)
       ContentService.Saving += ContentService_Saving; // rasied before the content has been saved.
     private void ContentService_Saving(IContentService contentService, SaveEventArgs<IContent> eventArgs)
       foreach (IContent node in eventArgs.SavedEntities)
           if (node.ContentType.Alias == Filtergroup.ModelTypeAlias)
              CheckMainFilterGroup(node, eventArgs);
    Sep 12, 2018 @ 14:53
    Alex Skrypnyk
    2
    Exactly, Frans, thank you so much.
    Sep 12, 2018 @ 15:18
    Dan Evans
    But i am updating a 3rd party web service. I need to do this when the document is published. I don't want to do it when a user may just be saving a draft of the document. My code needs to do 2 things. Update a 3rd party web service when the document is published, then update an Umbraco property with a returned value...
    //update 3rd party web service:
    //take returned value and update umbraco property
    Sep 13, 2018 @ 06:53
    Frans de Jong
    Ok, now I understand. The infinite loop is logical in that case. You ask tell it to publish when publishing tho the event triggers again and again.
    What happens if you use the publishing event? If you do a normal save there it will happen before the actual publishing. I expect that is the effect you are looking for?
    Sep 13, 2018 @ 11:01
    Dan Evans
    Yes, that's perfect! I thought I'd tried the Publishing event but clearly not! Thanks very much for your help.
