I have tried quering the data in the database - or more specific in uCommerce_PurchaseOrder, where I need to get orders within a daterange, where the column CompletedDate is a datetime allowing null values.
var sqlQuery = "SELECT * FROM uCommerce_PurchaseOrder o";
var sql = new Sql(sqlQuery);
Sql filterSql = new Sql();
var pageIndex = 0;
var pageSize = 100;
var start = new DateTime(2018, 1, 1);
var end = DateTime.Now;
filterSql.Where("o.CompletedDate IS NOT NULL")
.Where("o.CompletedDate >= @start", new { start = start }, DatabaseContext.SqlSyntax)
.Where("o.CompletedDate <= @end", new { end = end }, DatabaseContext.SqlSyntax);
sql.Append(filterSql);
// Get page of results and total count
var pagedResult = _db.Page<OrderModel>(pageIndex + 1, pageSize, sql.SQL);
int totalRecords = Convert.ToInt32(pagedResult.TotalItems);
With the .Where() clauses for start and end date it doesn't return any results, but without these it does.
I have tried with a different format as well without luck:
filterSql.Append("WHERE o.CompletedDate IS NOT NULL");
filterSql.Append("AND o.CompletedDate >= @start AND o.CompletedDate <= @end",
new
start = start,
end = end
Just in case someone else queries this too, I used the standard BETWEEN clause in SQL:
.Where(@"EventsId IN (@eventsIds) AND ( (StartDAte BETWEEN @1 AND @2) OR (EndDate BETWEEN @1 AND @2) OR (StartDate <= @1 AND EndDate >= @2))",
new { eventsIds = eventsIds },
fromDate.Date,
toDate.Date)); // + 1 to make sure the we find a full day.
This finds all events that start or end within the date range and for events that span the selected date range.
Query data between two dates with PetaPoco
datetimeallowing null values.With the
.Where()clauses for start and end date it doesn't return any results, but without these it does.I have tried with a different format as well without luck:
Any idea what I am missing in the queries?
/Bjarne
I found another way to solve this, but I don't know why regular SQL expression didn't seem to work with the datetime parameters.
