  • ssougnez 93 posts 319 karma points c-trib
    Oct 09, 2018 @ 15:17
    ssougnez
    Custom validation for custom property editor
    I'm creating a simple property editor:
    <div>
        <input id="page-url" type="text" class="umb-editor umb-text-string" ng-model="model.value" val-property-validator="validateUrl"  />
    The code from "validateUrl" is the following:
    this._$scope.validateUrl = () => {
        return {
            isValid: !this._$scope.error,
            errorMsg: "This URL is already associated to another page",
            errorKey: "pageUrlValidation"
    Nothing really fancy here but I have a weird behavior. Indeed, with this code, the value of "model.value" is never shown in the "input". Moreover, what I type in it, "model.value" is not updated, it's like "ng-model" was not applied. Therefore, when I try to save the node, the validation function always execute on the same value. I tried to display "model.value" on the page and I can see that the value is never updated.
    The value of "_$scope.error" is updated when the user types in the input.
    Note that if I remove the "val-property-validator" attribute, the "ng-model" applies correctly but then I'm unable to apply custom validation on it.
    When I looked in UmbracoCms repo, I noticed that fields with the validation are often hidden (I didn't check all the files) but I guess it's because the UI forces it...
    Am I missing something here?
  • Jamie Freeman 38 posts 151 karma points
    Oct 10, 2018 @ 10:20
    Jamie Freeman
    have you tried doing something like
    <div ng-scope="model">
      <input id="page-url" type="text" class="umb-editor umb-text-string" ng-model="value" val-property-validator="validateUrl"  />
    equally (without knowing the rest of the scope) have you tried just value
    <div>
    Oct 10, 2018 @ 13:52
    ssougnez
    I'll try that but after some research it turns out it's an Angular issue. When you use a directive that requires "ngModel", you have to use "$parent" in the binding to make it works... I created a custom directive to see what was the issue and solved the issue by using this trick.
  • Dan White 206 posts 510 karma points c-trib
    Mar 05, 2019 @ 01:36
    Dan White
    Could you provide an example how you got it working?
    Mar 05, 2019 @ 07:22
    ssougnez
    it's a long time ago so I don't remember well but here are the relevant part of my code. First of all, I changed a bit the purpose of the validator. It just checks whether a boolean is true/false.
    Here is the HTML where I use it:
    <input type="text"
           ng-model="$parent.$ctrl.model.value"
           property-boolean-validator="$parent.$ctrl.error"
           property-boolean-validation-error-message="This URL is already used by another page."
           property-boolean-validator-key="uniqueUrl" />
    The trick here is to use "$parent" in the HTML instead of directly "$ctrl" as AngularJs 1.x as this issue. Note that in the code, I also listen to input event on the textbox with RxJs (to use debounceTime) and change the value of $ctrl.error based on the entered value.
    Now, the code of the directive (it's TS):
    export function PropertyBooleanValidatorDirective(): ng.IDirective {
        return {
            restrict: "A",
            scope: {
                propertyBooleanValidator: '=',
                propertyBooleanValidationErrorMessage: '@',
                propertyBooleanValidatorKey: '@'
            require: ["ngModel", "?^umbProperty"],
            link: (scope: IPropertyBooleanValidatorScope, element: ng.IAugmentedJQuery, attrs: ng.IAttributes, ctrls: ng.IController[]) => {
                var modelCtrl = ctrls[0] as ng.INgModelController;
                var propCtrl = ctrls.length > 1 ? ctrls[1] : null;
                if (propCtrl) {
                    scope.$watch(() => scope.propertyBooleanValidator, (nv: boolean) => {
                        modelCtrl.$setValidity(scope.propertyBooleanValidatorKey, !nv);
                        if (nv === true) {
                            propCtrl.setPropertyError(scope.propertyBooleanValidationErrorMessage);
                        else {
                            propCtrl.setPropertyError(null);
    So basically I just watch the value of the attributes and update the field validity based on its value.
