Both servers are registered in the umbracoServer table server correctly and the umbracoApplicationUrl is set to the primary domain for the site in the umbracoSettings.config file.
Changes are published on Server 1 fine and the PageCacheRefresher.CacheUpdated event is fired on the master. The cache instructions in the database are processed by the slave server but the PageCacheRefresher.CacheUpdated event does not appear to fire on the slave server yet the lastsync value is updated and so is the umbraco.config cache file.
Thanks Dave, that's really useful to have some context relating to the change in behaviour and it turns out it addresses another unresolved issue I kept seeing in regards to "DISTRIBUTED CACHE NOT UPDATED" errors in the logs in previous versions.
Maybe you can create a fake umbraco context if you need it.
I think in actual fact I can remove the check now as it is already redundant based on the issue you have referenced.
Load Balanced Site - PageCacheRefresher.CacheUpdated Does Not Seem to Fire on Slave Server
I have a large multi-site install load balanced using a Flexible Load Balancing setup.
I am subscribing to the
PageCacheRefresher.CacheUpdatedevent in theApplicationStartedevent of myApplicationEventHandleras follows:Both servers are registered in the
umbracoServertable server correctly and theumbracoApplicationUrlis set to the primary domain for the site in the umbracoSettings.config file.Changes are published on Server 1 fine and the
PageCacheRefresher.CacheUpdatedevent is fired on the master. The cache instructions in the database are processed by the slave server but thePageCacheRefresher.CacheUpdatedevent does not appear to fire on the slave server yet the lastsync value is updated and so is the umbraco.config cache file.Any ideas what might cause that to happen?
Hi Simon,
What version are you running ? We noticed that in one of the latest versions UmbracoContext.Current is always null in the cache updated event.
Could you remove that line to check this and see if something is written to the log ?
Dave
Hi Dave
This site is running 7.10.4. I will see about removing that line this morning in the next deployment and let you know.
Thanks, Simon
You are indeed correct Dave -
UmbracoContext.Current == nullnow on the slave server when the event is triggered so thanks for pointing that out.Hi Simon,
I noticed this as well. In earlier versions this was set.
This was a breaking change in 7.8.0 I know found out : https://issues.umbraco.org/issue/U4-10150
Don't know if this gist is still working : https://gist.github.com/sniffdk/7600822
Make sure to read all the comments
Dave
Thanks for your help Dave, much appreciated.
