  • Jay 425 posts 652 karma points
    Nov 22, 2018 @ 15:57
    Jay
    PageCacheRefresher and MessageType.RefreshById no longer works with UmbracoContext.Current V7.12.3
    I've been trying to hook into the Distributed call events using
    CacheRefresherBase<PageCacheRefresher>.CacheUpdated += this.PageCacheRefresherCacheUpdated;
    and then using
    private void PageCacheRefresherCacheUpdated(PageCacheRefresher sender, CacheRefresherEventArgs e)
                if (e?.MessageObject != null)
                    if (e.MessageType == MessageType.RefreshById)
                        var item = UmbracoContext.Current.ContentCache.GetById((int)e.MessageObject);
    But UmbracoContext.Current is always null when this gets hits in the Slave machine. Has this been changed in the new version of Umbraco V7.12.3?
    I remember it used to work before in an older version
    Nov 22, 2018 @ 15:59
    Jay
    Been digging around, used to work like in this example to call ContentCache https://github.com/Shazwazza/Articulate/blob/master/src/Articulate/UmbracoEventHandler.cs#L115
  • Søren Gregersen 441 posts 1884 karma points MVP 2x c-trib
    Nov 22, 2018 @ 18:33
    Søren Gregersen
    The call is initiated via a scheduled task (AFAIK), and you can't be sure that the umbraco context is available, when there is no webrequest involved.
    Take a look at https://github.com/Shazwazza/Articulate/blob/master/src/Articulate/UmbracoEventHandler.cs#L109 ;)
  • Jeavon Leopold 3074 posts 13632 karma points MVP 11x admin c-trib
    Nov 23, 2018 @ 08:59
    Jeavon Leopold
    This is due to this breaking change in v7.8.0+ https://issues.umbraco.org/issue/U4-10150
    Nov 23, 2018 @ 09:25
    Jay
    Thanks Jeavon. No wonder
    Nov 23, 2018 @ 12:14
    Dave Woestenborghs
    You can create your own fake umbracocontext and use that if you need it
    var httpContext = new HttpContextWrapper(HttpContext.Current ?? new HttpContext(new SimpleWorkerRequest("temp.aspx", "", new StringWriter())));
    var umbContext = UmbracoContext.EnsureContext(
                httpContext,
                ApplicationContext.Current,
                new WebSecurity(httpContext, ApplicationContext.Current),
                UmbracoConfig.For.UmbracoSettings(),
                UrlProviderResolver.Current.Providers,
                false);
    Dave
    Nov 26, 2018 @ 14:19
    Jay
    Thanks Dave, will try that out
    Nov 26, 2018 @ 15:06
    Jay
    Seems to work. Thanks Dave
