  • David Amri 214 posts 740 karma points
    Jan 10, 2019 @ 09:06
    David Amri
    Index multi level nested content
    Hi, I'm trying to index multilevel nested content without any success. I'm able to break out the values one level down but as I have multi level nested content the second level writes out the JSON data as one string. Any help would much appreciated.
    The code looks like this:
    using Examine;
    using Umbraco.Core;
    using System.Linq;
    using Newtonsoft.Json;
    using Newtonsoft.Json.Linq;
    namespace Custom.Controllers
        public static class StringExtensions
            public static bool DetectIsJson(this string input)
                input = input.Trim();
                if (input.StartsWith("{") && input.EndsWith("}"))
                    return true;
                if (input.StartsWith("["))
                    return input.EndsWith("]");
                else
                    return false;
        public class ExamineJsonIndexer : ApplicationEventHandler
            protected override void ApplicationStarted(UmbracoApplicationBase umbracoApplication, ApplicationContext applicationContext)
                base.ApplicationStarted(umbracoApplication, applicationContext);
                // Declare the indexers that should index JSON properties
                var jsonIndexer = ExamineManager.Instance.IndexProviderCollection["KundUnikumContentIndexer"];
                if (jsonIndexer != null)
                    jsonIndexer.GatheringNodeData += (sender, e) =>
                        // Extract JSON properties
                        var fieldKeys = e.Fields.Keys.ToArray();
                        foreach (var key in fieldKeys)
                            var value = e.Fields[key];
                            // Check if index field is JSON data
                            if (value.DetectIsJson())
                                IndexNestedObject(e.Fields, JsonConvert.DeserializeObject(value), key);
            private void IndexNestedObject(Dictionary<string, string> fields, object obj, string prefix)
                var objType = obj.GetType();
                if (objType == typeof(JObject))
                    var jObj = obj as JObject;
                    if (jObj != null)
                        foreach (var kvp in jObj)
                            var propKey = prefix + "___jobject___" + kvp.Key;
                            var valueType = kvp.Value.GetType();
                            if (typeof(JContainer).IsAssignableFrom(valueType))
                                IndexNestedObject(fields, kvp.Value, propKey);
                            else
                                fields.Add(propKey, kvp.Value.ToString().StripHtml());
                else if (objType == typeof(JArray))
                    var jArr = obj as JArray;
                    if (jArr != null)
                        for (var i = 0; i < jArr.Count; i++)
                            var itm = jArr[i];
                            var propKey = prefix + "_jarray_" + i;
                            var valueType = itm.GetType();
                                IndexNestedObject(fields, itm, propKey);
                            else
                                fields.Add(propKey, itm.ToString().StripHtml());
  • Hendy Racher 863 posts 3849 karma points MVP 2x admin c-trib
    Jan 10, 2019 @ 09:12
    Hendy Racher
    Hi David,
    You might like to have a look at Look again, it now does this out of the box with a custom Examine indexer/searcher (unfortunately the docs are a little out of date and are being worked on, but happy to help out if I can...)
    Or if you want to roll-your-own, then from this source line might be useful, and the extension method GetFlatDetachedDescendants.
    Jan 10, 2019 @ 09:43
    David Amri
    Hi Hendy, been a long time since the last time :D
    Anyway, how does your code index the json data? I cant find any "json checking" in your code or is this done in some referenced library?
    Best regards David
    Jan 10, 2019 @ 09:50
    Hendy Racher
    Hi David,
    I think I'm going about it slightly differently - it doesn't parse Json, instead it requests the nested content item as IEnumerable < IPublishedContent > (recursively) and indexes each as a new Lucene document - so the idea is that each nested content item will be indexed in the same way as a regular node - might spark some ideas ?
    Could you do the same kind of thing, avoid JSON parsing, and recurse collections of IPublishedContent to then flatten out then store custom fields on the 'hosting' node ?
    Jan 10, 2019 @ 13:02
    David Amri
    I will try that Hendy. I feel like I'm kind of out of my comfort zone here... but I will certainly try.
    Is there anything more I have to consider except for the links you referred to? Any changes in the examine settings or index?
    Thanks /David
    Jan 11, 2019 @ 13:48
    David Amri
    Found a updated version of Matt Brailsford's snippet that handles nested in nested content.
  • Stefano Beretta 102 posts 247 karma points
    Jun 28, 2019 @ 10:56
    Stefano Beretta
    Hi!
    I successfully use this snippet to index a nested content used by a member, thank you!!!
    Can someone help me to find the code to filter members by a specific property of the nested content?
    Thank you!
    S
