I have been trying to integrate newsletter capabilities for a customer's web site, using Mailjet API.
Official Mailjet API v3 .NET Wrapper uses asynchronous functions in order to contact the service. I have a SurfaceController, that gets an Id and tries to retrieve a contact from the Mailjet service.
In order to use the retrieve method I used something like this:
public class PageNewsletterFormController : RenderMvcController
public override ActionResult Index(RenderModel model)
string ContactID = Request.QueryString["id"];
ContactModel contact = new ContactModel(model.Content);
JArray result = null;
MailjetClient client = new MailjetClient(WebConfigurationManager.AppSettings["apiKey"],
WebConfigurationManager.AppSettings["apiSecret"]) { Version = ApiVersion.V3_1 };
MailjetRequest request = new MailjetRequest
Resource = Contact.Resource
.Filter(Contact.ContactsList, WebConfigurationManager.AppSettings["contactslist"])
.Filter(Contact.ID, ContactID)
.Filter(Contact.Limit, "50");
MailjetResponse response = client.GetAsync(request).Result;
return CurrentTemplate(contact);
As soon as the code hits the GetAsync() method the page freezes.
I tried to do the same with something like this:
public async Task<ActionResult> NewsletterForm(RenderModel model)
I guess you're encountering a deadlock issue here. Looking at the above sample code I can't find an await keyword within an async method.
Try using the await keyword e.g MailjetResponse response = await client.GetAsync(request);
(Not the best solution) If within a non async method like i would expect in a SurfaceController (ChildActionOnly) then try calling using this MailjetResponse response = Task.Run(async => await client.GetAsync(request)).GetAwaiter().GetResult();
Using Official Mailjet API v3 .NET Wrapper from Surface controller.
It has the same problem - it freezes.
Is there someone that can offer any pointers?
Thanks, George J.
Bump - Having the same problem here (in fact, we're both working on the same project and we're stuck on this). Any advice?
You may have already tried some these...
Hope it helps. Cheers
