Here is my problem, how can I get the image url for each product?
System.Web.Http.HttpGet]
public List<KeyValuePair<int, string>> ComparisonKeyValues(string ids)
if (!string.IsNullOrEmpty(ids))
var nodes = ids.Split(',').ToList().TypedContentList();
return nodes.Select(x => new KeyValuePair<int, string>(x.Id, x.GetPropertyValue<string>("title"))).ToList();
// I want to get also the x.GetPropertyValue<string>(productImage).Url
return new List<KeyValuePair<int, string>>();
Depends... what is productImage ? A property, an object (don't think this code will compile, don't see productImage defined somewhere?
If it's a property, which I'm assuming ,because you're using x.GetPropertyValue(), then it will still depend on how productImage property was defined? Either as upload or a media picker?
If the first, then
x.GetPropertyValue<string>("productImage")
will already return path to the image, otherwise, you'd need to
Yes it's a property, but when I add x.GetPropertyValue<string>("productImage") it says KeyValuePair does not contain a constructor that takes 3 arguments.
return nodes.Select(x => new KeyValuePair<int, string>(x.Id, x.GetPropertyValue<string>("title"), x.GetPropertyValue<string>("productImage")).ToList();
if you want to use the current format of KeyValuePair<>, you'd have to extend the second generic type to accept multiple values, so would be something along the lines of
[System.Web.Http.HttpGet]
public List<Compares> CompareValues(string ids)
var result = new List<Compares>();
/// Error : Cannot implicity convert type 'System.Collections.Generic.List....
// what should I put in here?
return result;
string[] listOdIds = ids.Split(new char[] { ',' });
foreach (var id in listOdIds)
var page = Umbraco.TypedContent(id);
var imageUrl = Umbraco.TypedMedia(page.GetPropertyValue<string>("image")).Url;
var comparess = new Compares()
Id = Convert.ToInt32(id),
Title = page.GetPropertyValue<string>("title"),
Url = imageUrl
result.Add(comparess);
return result;
return result;
How to get 3 values using KeyValuePair
Hi All,
Sorry for noob question.
image urlfor each product?Any help for this?
Thanks in advance.
I am new in C#, and also in Umbraco.
Jin
If the first, then
which returns a IPublishedContent, from where you can do .Url to get the path to the image
Hi Dirk,
x.GetPropertyValue<string>("productImage")it saysKeyValuePair does not contain a constructor that takes 3 arguments.I want to return
ID, title, and Url.Thanks for your response.
Jin
Or you have any idea on how I can get all the properties using their
idsI want to get also the
productImageproperty.Any help for this, I'm stuck on this problem.
Thanks in advance,
Jin
which I believe is a bit overkill, why not create a specific class holding three properties and return as
Example:
and return a
from your method
Hi Dirk
What do you mean by overkill??
Like this?
Thanks dude.
Marky
Overkill = list of keyvaluepair where value is again a dictionary, bit too complex for what you'd need (and doesn't make it easier to read)
Okay..
Is still got an error
Marky
Because nodes.Select returns IEnumerable
Oh,
How can I rid of this? Any alternative way?
Sorry for my noob question, I really new in C# & Umbraco :(
Marky
Hi Dirk
I've got the correct code, thanks for your help.
Here what I've done.
Marky
