Hi Guys,
I am using UmbracoFileSystemProviders.Azure to setup Umbraco media files to use an Azure storage account.
I have requirement to create media(Image) in azure blob storage using c# code. Here is the code I used before with local file system.
public int SaveImage(string url, int mediaNodeId) { try { var mediaService = Services.MediaService; string originalFileName = Path.GetFileName(url); string filenameToSave = Path.GetFileNameWithoutExtension(originalFileName) + Guid.NewGuid() + Path.GetExtension(originalFileName); string imageUrl = url; // Get file URL string saveLocation = Server.MapPath("~/Imports/" + filenameToSave); // The file will downloaded into a folder in root byte[] imageBytes; HttpWebRequest imageRequest = (HttpWebRequest)WebRequest.Create(imageUrl); WebResponse imageResponse = imageRequest.GetResponse(); Stream responseStream = imageResponse.GetResponseStream(); using (BinaryReader br = new BinaryReader(responseStream)) { imageBytes = br.ReadBytes(500000000); br.Close(); } responseStream.Close(); imageResponse.Close(); FileStream fs = new FileStream(saveLocation, FileMode.Create);//save the image to the root folder BinaryWriter bw = new BinaryWriter(fs); bw.Write(imageBytes); var mediaImage = mediaService.CreateMedia(originalFileName, mediaNodeId, "Image"); mediaImage.SetValue("umbracoFile", originalFileName, fs);//setting filestream to UmbracoFile mediaService.Save(mediaImage);//Save media fs.Close(); bw.Close(); return mediaImage.Id; } catch (Exception ex) { } return 0; }
The above code is not working when I am trying to create image to Azure blob storage. Please help!
Create Media on Azure Blob Storage Using C#
Hi Guys,
