  • Andrew Watt 22 posts 124 karma points
    Apr 09, 2019 @ 16:03
    Andrew Watt
    Allow <style> tags in RTE
    I can't figure out how to allow style tags in the RTE. I've tried allowing them in validElements. It doesn't seem to even get to that point. They are being stripped out somehow when I switch from code view back to editor view, before I try to save the page. Is there some basic setting I'm missing?
    Apr 09, 2019 @ 16:32
    Alex Skrypnyk
    Hi Andrew
    Did you try to add stylesheet file to RTE? Go to Developers section => Data Types => select RTE you use => enter image description here
    in "Stylesheets" block choose the file you need to add to RTE
    Alex
    Apr 09, 2019 @ 17:30
    Andrew Watt
    Yes, we can add stylesheets. However we would like the ability to add style tags on a page by page basis if possible. We may have some landing pages on the site that have a very different look and feel.
  • CornĂ© Strijkert 80 posts 456 karma points c-trib
    Apr 09, 2019 @ 18:36
    Corné Strijkert
    We accidentally had the same discussion today. We would like to embed some 'things' that contains styles, scripts and more.
    I think you should search for another approach and not using RTE for this purposes. Rich content editors are mainly for textual editing.
    Maybe you can add a property on you landing page content type that selects the right stylesheet? When you have a lot of different styles for RTE I think the default approach to add styles to RTE is not going to work well.
