I have an API controller that serializes Content nodes to json. I'm using the ContentCache to lookup the content by Url, which works as intended.
However, when nodes are renamed and thus a redirection is created, I'd like to return a 301 instead for the old URLs. The problem is the ContentCache doesn't seem to recognize redirections.
Does anybody have any suggestions on how I might be able to identify redirected URLs and return a 301? Do I need to implement a custom ContentFindER? Or am I over thinking it?
Any help is greatly appreciated! For info, here is my controller action;
[HttpGet]
[Route("get/?url={url}")]
public object Get(string url)
var content = UmbracoContext.ContentCache.GetByRoute(url);
if(content == null) throw new HttpResponseException(HttpStatusCode.NotFound);
return new ContentDataModel(content);
The way the Redirect Url Management functionality works is the redirect is stored in a separate database table to the Umbraco Cache, and the Cache takes precedent, so if a route isn't in the Umbraco Cache, then just before serving a 404, Umbraco will look to see if a redirect exists in the umbracoRedirectUrl database table. So I think in your scenario you can just do the same eg:
[HttpGet]
if(content == null) {
//no matching published Umbraco content, let's see if a redirect exists:
// Umbraco has a core RedirectUrlService that queries the db with a snappily name method called GetModeRecentRedirectUrl...
IRedirectUrl redirectUrl = Services.RedirectUrlService.GetMostRecentRedirectUrl(url);
// (now I'm not sure what format your url is in, but this method is expecting an Umbraco route, which if you have domains set will need the prefix of the route domain id see: https://github.com/umbraco/Umbraco-CMS/blob/v7/dev/src/Umbraco.Web/Routing/ContentFinderByRedirectUrl.cs#L23 for an example)
if (redirectUrl!=null){
// we have a redirect!
var targetRedirectId = redirectUrl.ContentId;
content = UmbracoContext.ContentCache.GetById(targetRedirectId);
if (content == null){
//the redirect content doesn't exist!
else {
// no redirect, no content, return not found
//somehow we have content!
Anyway that's the gist if I've understood correctly!
Identify redirections when using GetByRoute
Hi guys,
Hi Philip
regards
Marc
Hi Marc,
Ah I never even thought to look in Services! Your answer is bang on the money though, it works a treat.
Thanks for the swift response + knowledge on how it works. Really appreciate it amigo. #h5yr
Kind regards
Phil
