Setting Grid Value from existing PropertyType - Programatically Move Prop and Value
Hi all I have a situation where I want to move a grid property type and it's value from one doc type to another programatically.
So I'm doing something like so:
foreach (var group in contentPageDocType.PropertyGroups.ToArray())
foreach (var prop in group.PropertyTypes.Where(pt => myPage.HasProperty(pt.Alias) && myPage.GetValue(pt.Alias) != null))
//Store the composed property type values so we can manually add them back in after removing the composition
composedPropertyValues.Add(new PropertyValueGroupStore { PropertyType = prop as PropertyType, PropertyValue = loyaltySummaryPage.GetValue(prop.Alias), GroupName = group.Name });
And then iterating over the built up properties, groupings etc and transferring them over to my other node of a given doc type and calling
Content.SetValue(propertyAlias, value);
This is creating the grid datatype but almost appears to be escaping the JSON and that json then appears in each grid row with an error in the admin section.
I originally tried property.DeepClone() unsucessfully.
Any advice would be most appreciated!!
