I have a blog and I have custom index which keeps information for my articles. Article has a property of type MNTP which needs to be searchable. In the index I see that the values of the MNTP looks like "umb://document/917ac780d3bd4208bd1001c8838c92a8". I have TransformingIndexValues(object sender, IndexingItemEventArgs e) method which needs to get the content item for this udi and save its name in the index. I used to work with umbracoHelper in Umbraco 7, but now in Umbraco 8 I receive error when I call:
I found the solution. Mainly the problem was getting item from ContentCache by UDI.
I have blog and my articles have MNTP which value I need to store in the index. I implement my TransformingIndexValues method:
public class CustomExamineComponent : IComponent
private readonly IExamineManager _examineManager;
private readonly CustomIndexCreator _indexCreator;
private readonly IUmbracoContextFactory _contextFactory;
public CustomExamineComponent(IExamineManager examineManager, CustomIndexCreator indexCreator, IUmbracoContextFactory contextFactory)
_examineManager = examineManager;
_indexCreator = indexCreator;
_contextFactory = contextFactory;
public void Initialize()
DirectoryFactory.DefaultLockFactory = d =>
var simpleFsLockFactory = new NoPrefixSimpleFsLockFactory(d);
return simpleFsLockFactory;
foreach (var index in _indexCreator.Create())
_examineManager.AddIndex(index);
if (index.Name == "NewsSearchIndex")
((BaseIndexProvider)index).TransformingIndexValues += CustomExamineComponent_TransformingIndexValues;
private void CustomExamineComponent_TransformingIndexValues(object sender, IndexingItemEventArgs e)
using (var ctx = _contextFactory.EnsureUmbracoContext())
var cache = ctx.UmbracoContext.ContentCache;
if (e.ValueSet.ItemType == "articleDetailsPage")
var categoryItem = e.ValueSet.Values["category"];
if (categoryItem != null)
Udi udi;
if (Udi.TryParse(categoryItem[0].ToString(), out udi))
//Get node by UDI
var guid = GuidUdi.Parse(udi.ToString());
var node = cache.GetById(guid.Guid);
Add values to indexset on TransformingIndexValues
Hi, I have a blog and I have custom index which keeps information for my articles. Article has a property of type MNTP which needs to be searchable. In the index I see that the values of the MNTP looks like
"umb://document/917ac780d3bd4208bd1001c8838c92a8". I have TransformingIndexValues(object sender, IndexingItemEventArgs e) method which needs to get the content item for this udi and save its name in the index. I used to work with umbracoHelper in Umbraco 7, but now in Umbraco 8 I receive error when I call:Thanks Mila
Hi I found the solution. Mainly the problem was getting item from ContentCache by UDI. I have blog and my articles have MNTP which value I need to store in the index. I implement my TransformingIndexValues method:
