  • Mila Pandurska 75 posts 354 karma points
    Jun 20, 2019 @ 12:16
    Mila Pandurska
    Examine Custom Index TransformingIndexValues
    I have configured custom index and TransformingIndexValues method to gather some additional information about nodes of type "article". The problem is that when I create new "article" and click "Save &Publish" for first time TransformingIndexValues is not fired (or doesn't work as expected). When I click second time "Save&Publish" everything is ok. Here is mu code: `
    private readonly IExamineManager _examineManager;
            private readonly CustomIndexCreator _indexCreator;
            private readonly IUmbracoContextFactory _contextFactory;
            public CustomExamineComponent(IExamineManager examineManager, CustomIndexCreator indexCreator, IUmbracoContextFactory contextFactory)
                _examineManager = examineManager;
                _indexCreator = indexCreator;
                _contextFactory = contextFactory;
            public void Initialize()
                //we want to tell examine to use a different fs lock instead of the default NativeFSFileLock which could cause problems if the AppDomain
                //terminates and in some rare cases would only allow unlocking of the file if IIS is forcefully terminated. Instead we'll rely on the simplefslock
                //which simply checks the existence of the lock file
                DirectoryFactory.DefaultLockFactory = d =>
                    var simpleFsLockFactory = new NoPrefixSimpleFsLockFactory(d);
                    return simpleFsLockFactory;
                foreach (var index in _indexCreator.Create())
                    _examineManager.AddIndex(index);
                    if (index.Name == "NewsSearchIndex")
                        ((BaseIndexProvider)index).TransformingIndexValues += CustomExamineComponent_TransformingIndexValues;
            private void CustomExamineComponent_TransformingIndexValues(object sender, IndexingItemEventArgs e)
                try
                    using (var ctx = _contextFactory.EnsureUmbracoContext())
                        var cache = ctx.UmbracoContext.ContentCache;
                        if (e.ValueSet.ItemType == "articleDetailsPage")
                            var categoryItem = e.ValueSet.Values["category"];
                            if (categoryItem != null)
                                //more than one category
                                string[] array = categoryItem[0].ToString().Split(',');
                                if (array.Length > 0)
                                    var sb = new StringBuilder();
                                    for (int i = 0; i < array.Length; i++)
                                        Udi udi;
                                        if (Udi.TryParse(array[i], out udi))
                                            //Get node by UDI
                                            var guid = GuidUdi.Parse(udi.ToString());
                                            var category = cache.GetById(guid.Guid);
                                            if (category != null)
                                                sb.Append(string.Format("{0} ", category.GetProperty("title").Value()));
                                    e.ValueSet.Add("categoryValue", sb.ToString());
                            //get the article
                            var article = cache.GetById(int.Parse(e.ValueSet.Id));
                            e.ValueSet.Add("year", article.Ancestor<YearFolder>().Name);
                            e.ValueSet.Add("month", article.Ancestor<MonthFolder>().Name);
                            e.ValueSet.Add("monthSortOrder", article.Ancestor<MonthFolder>().SortOrder);
                            e.ValueSet.Add("yearSortOrder", article.Ancestor<YearFolder>().SortOrder);
                catch (Exception ex)
                    throw;
    When I create item and click "Save&Publish" and then go to examine Indexes and check the item my custom fields are not there. After clicking ""save&publish" second time and to go the index - my custom values are there. I am thinking that may be on first Save&Publish the index of the node is not created yet and I have to ensure that it exists and then add additional values.
    Please help
    Jun 26, 2019 @ 08:04
    Mila Pandurska
    I figured out that the problem is not TransformingIndexValues method, but the umbrao cache that I try to use:
    At that time this node is not in the umbraco cache. And here somes the next quetion: how to access this item in order to get the additional values?
