  • Kristoffer Lindén 12 posts 122 karma points
    Jul 08, 2019 @ 11:37
    Kristoffer Lindén
    New section not showing
    Hi!
    I'm trying to add a new section by code but I can't get it to show:
        composition.Sections().Append<MySection>();
    The section:
    public class MySection : ISection
        public string Alias => "mySection";
        public string Name => "My Section";
    The section gets added to the collection but nothing is rendered?
    Any ideas why?
    Thanks!
    /Kristoffer
  • Kevin Jump 2346 posts 14894 karma points MVP 8x c-trib
    Jul 08, 2019 @ 12:27
    Kevin Jump
    Hi Kristoffer,
    By default, a new section won't display until you have added it to the list of visible sections for a user group.
    If you go to the users' section, click on groups in the top right-hand corner
    select administrators
    and then add the section to the list,
    save and then refresh the browser, the section should appear.
    Programmatically.
    you can add a section to a user group - (this would be a one off task) - something like :
        private void AddSectionToGroup(string groupAlias, string sectionAlias)
            var group = userService.GetUserGroupByAlias(groupAlias);
            if (group != null)
                if (!group.AllowedSections.Contains(sectionAlias))
                    group.AddAllowedSection(sectionAlias);
                    try
                        userService.Save(group);
                    catch (Exception ex)
                           // oh dear :( it went wrong
    Kevin
    Jul 08, 2019 @ 13:35
    Kristoffer Lindén
    Thanks Kevin, works just perfect!
    /Kristoffer
