  • nickornotto 403 posts 907 karma points
    Jul 10, 2019 @ 19:04
    nickornotto
    Trouble disaplying custom section in Umbraco 7.6
    I am trying to build a new section in Umbraco 7.6.
    I had this working the 'old' way that use the tree controller extending from BaseTree but it was very ugly.
    I'm now trying to do it using TreeController. I have followed the tutorials by:
    1. Kevin Giszewski (https://github.com/kgiszewski/LearnUmbraco7/blob/master/Chapter%2016%20-%20Custom%20Sections%2C%20Trees%20and%20Actions/01%20-%20Create%20a%20Section.md)
    2. and another by Tim Geyssens (https://github.com/TimGeyssens/UmbracoAngularBackofficePages)
    but all I'm getting is an empty section without the tree and just with the title:
    The controllers are not even hit on debugging, no console errors, no 500 errors, all compiles fine too.
    Here's my code:
    trees.config:
    <add initialize="true" sortOrder="0" alias="UmbracoBookshelfTree" application="UmbracoBookshelf" title="Umbraco Bookshelf" iconClosed="icon-folder"
        iconOpen="icon-folder-open" type="UmbracoBookshelf.Controllers.UmbracoBookshelfTreeController, MyWebsite.Backoffice"/>
    applications.config:
    <add alias="UmbracoBookshelf" name="Umbraco Bookshelf" icon="icon-globe-inverted-america" sortOrder="5"/>
    Section:
    using umbraco.businesslogic;
    using umbraco.interfaces;
    namespace UmbracoBookshelf.Applications
        [Application("UmbracoBookshelf", "Umbraco Bookshelf", "icon-globe-inverted-america", 5)]
        public class UmbracoBookshelfApplication : IApplication
    Tree controller:
    using System;
    using System.Linq;
    using System.Net.Http.Formatting;
    using System.Web;
    using umbraco;
    using umbraco.BusinessLogic.Actions;
    using Umbraco.Core;
    using Umbraco.Web.Models.Trees;
    using Umbraco.Web.Mvc;
    using Umbraco.Web.Trees;
    namespace UmbracoBookshelf.Controllers
        [PluginController("UmbracoBookshelf")]
        [Umbraco.Web.Trees.Tree("UmbracoBookshelf", "UmbracoBookshelfTree", "Umbraco Bookshelf", iconClosed: "icon-folder")]
        public class UmbracoBookshelfTreeController : TreeController
            protected override Umbraco.Web.Models.Trees.MenuItemCollection GetMenuForNode(string id, System.Net.Http.Formatting.FormDataCollection queryStrings)
                var menu = new MenuItemCollection();
                if (id == Constants.System.Root.ToInvariantString())
                    // root actions
                    menu.Items.Add<CreateChildEntity, ActionNew>(ui.Text("actions", ActionNew.Instance.Alias));
                    menu.Items.Add<RefreshNode, ActionRefresh>(ui.Text("actions", ActionRefresh.Instance.Alias), true);
                    return menu;
                else
                    //menu.DefaultMenuAlias = ActionDelete.Instance.Alias;
                    menu.Items.Add<ActionDelete>(ui.Text("actions", ActionDelete.Instance.Alias));
                return menu;
            protected override TreeNodeCollection GetTreeNodes(string id, FormDataCollection queryStrings)
                var nodes = new TreeNodeCollection();
                nodes.Add(CreateTreeNode("123", "456", queryStrings, "Some name to be shown"));
                nodes.Add(CreateTreeNode("789", "456", queryStrings, "Some other name to be shown"));
                return nodes;
    It's pretty simple, what could wrong here?
