Angular errors when setting defaultDate on <umb-flatpickr> date pickers inside an ng-repeat loop
Hi there,
I have a personal side-project for a holiday lettings website, and I'm developing a custom property editor to manage occupancy and rates.
The intention is to be able to specify a series of items containing a start date and a set of rates (depending on the number of people occupying the property).
Here's a design concept for the property editor:
This requires a date picker to be inside an ng-repeat loop. I've almost got it working, but I'm getting a ton of Angular errors when I'm setting the initial values of the date pickers from the data model.
A bit of background:
The initial date of an umb-flatpickr element is set via the 'defaultDate' property of an options object. When you only have a single date picker, you can just define the options object in your controller, and set the defaultDate there. However, when it's inside an ng-repeat, it needs to be set for each iteration.
$scope.defaultDateTimeConfig = {
weekNumbers: true,
altInput: true,
altFormat: "F j, Y",
dateFormat: "Y-m-d",
onChange: function(selectedDates, dateStr, instance) {
var rootIndex = instance.element.parentElement.parentElement.getAttribute('data-index'); // hacky, much?
$scope.model.value.rates[rootIndex].fromDate = dateStr;
// set current year to this one
var thisYear = new Date(dateStr).getFullYear();
if (thisYear != $scope.showYear) {
$scope.showYear = thisYear;
calculateAllYears();
$scope.dateOptions = function(dateStr) {
return angular.extend({ defaultDate: new Date(dateStr) }, $scope.defaultDateTimeConfig);
So, I'm defining an object for all the common settings, and then using a function to extend that object with a defaultDate property which takes a value passed to the function.
So, the 'options' attribute is calling the dateOptions function and passing in the value from the data model.
This all works. Yay me.
However.... in Chrome dev tools, I'm seeing an absolute ton of Angular errors:
My Angular is rudimentary, so I'm not totally sure what's going on here, but I suspect that having the default options and/or function in $scope is creating a load of unnecessary watches?
I'm hoping that someone with more Angular knowledge than me will know a better / correct way to do this that doesn't spit out hundreds of console errors.
All the code's on Github here - any pointers would be much appreciated!
(Side note: getting the data model to update properly when you change the date in the picker was 'fun' - that's working too, but it's also super-hacky! Be nice!)
According to this https://docs.angularjs.org/error/$rootScope/infdig it can happen when you bind your ng-repeat to a dynamic collection and whilst your collection isn't dynamic (rates) you do have a change handler which alters it so I think you have a bit of an infinite loop.
Repeat over rates
Render date picker binding options causing a change event
Change triggers onchange which modifies a value inside rates collection
Angular sees the change and thinks it needs to re-render the list
Hi there,
In my controller, I'm doing this:
In my view, I'm doing this:
According to this
https://docs.angularjs.org/error/$rootScope/infdigit can happen when you bind your ng-repeat to a dynamic collection and whilst your collection isn't dynamic (rates) you do have a change handler which alters it so I think you have a bit of an infinite loop.This is my guess anyways
Matt
OK - I think I have it sorted (but still a bit nasty).
I'm no longer sending the defaultDate setting to the function. Instead, I'm adding a value attribute to the view element:
And then grabbing this from the onReady event in the defaultDateTimeConfig options in the controller:
No console errors, and everything seems to be updating. Phew.
Thanks for looking at it Matt (and Nik).
Time for wine and sleep.
