  • Thomas Kassos 54 posts 264 karma points
    Aug 19, 2019 @ 15:45
    Thomas Kassos
    Examine index with custom data. How to Add and Remove items ?
    Hi!
    I have create an Examine Index with custom data following the steps from this article https://24days.in/umbraco-cms/2016/custom-data-and-examine-searching/.
    From this article I have implement only the solution till to create the Index and no to rebuild it.
    What I am trying to achieve is a better approach to update the Index and no to rebuild the entire Index every few minutes. I am trying to add a node to examine Index on publish and remove it on UnPublush and on Trashed events.
    To achieve that I have create a event handler
        protected override void ApplicationStarted(UmbracoApplicationBase umbracoApplication, ApplicationContext applicationContext)
            ContentService.Published += ApiPage_Published;
            ContentService.UnPublished+= ApiPage_UnPublished;
            ContentService.Trashed += ApiPage_Trashed;
    First I start working with the ApiPage_Trashed
        private void ApiPage_Trashed(IContentService sender, MoveEventArgs<IContent> e)
            var nodeID = e.Entity.ContentType.Id.ToString();
            try
                ExamineManager.Instance.IndexProviderCollection["ApiPageIndexer"].DeleteFromIndex(nodeID);
                var query = "Dynamic";
                var searcher = ExamineManager.Instance.SearchProviderCollection["ApiPageSearcher"];
                var searchCriteria = searcher.CreateSearchCriteria();
                var searchQuery = searchCriteria.Field("nodeName", query);
                var searchResults = searcher.Search(searchQuery.Compile()).ToList();
                LogHelper.Info<string>($"node with id {nodeID} has been removed from ApiPageIndexer");
            catch (Exception ex)
                LogHelper.Error<ContentEvents>($"node with id {nodeID} has faild to be removed from ApiPageIndexer", ex);
    (the search code exists only for the debugging)
    So the code runs without any error but the Node still exist in the Index.
    Am I missing something? any ideas on that?
    Also does anyone know how I can add a node to the Index?
    Thanks, Thomas
    Oct 22, 2019 @ 10:41
    Thomas Kassos
    I had found what was wrong, I was picking the wrong Id
    this id was from the document type and no from the node. Bellow I am sharing my approach - It's working! :)
               try
                    foreach (var node in e.MoveInfoCollection)
                        if (node.Entity.ContentType.Alias == ApiVersion.ModelTypeAlias)
                            ExamineManager.Instance.IndexProviderCollection[ExamineAliases.ApiPageIndexerName].DeleteFromIndex(node.Entity.Id.ToString());
                    LogHelper.Error<ContentEvents>("bla bla", ex);
