    Aug 21, 2019 @ 16:24
    Ismail Mayat
    Umbraco xpath issue
    I am trying todo the following in umbraco 7.5.3
        string feedXpath = "/root/HomePage/ListPage//*[@nodeType='" + @docTypeId + "']";
    var feedItems = Umbraco.TypedContentAtXPath(feedXpath);
    This xpath gives me 44 items. However I have more than that. When i open the xml config cache file in notepad++ and run generated xpath i.e
    /root/HomePage/ListPage//*[@nodeType='1599']
    I get the right number. Is there a bug with xpath in Umbraco?
    Regards
    Ismail
  • Chriztian Steinmeier 2800 posts 8791 karma points MVP 8x admin c-trib
    Aug 21, 2019 @ 18:21
    Hi Ismail,
    I'd say you should look in the implementation of TypedContentAtXPath() - it may filter out nodes that for some reason can't be converted to complete models?
    Are the 44 you get by any chance "top" levels (i.e., are all the missing ones descendants of those 44)?
    /Chriztian
    Aug 22, 2019 @ 12:15
    Ismail Mayat
    Seems like missing ones are descendants. For now i am going to do it with Descendants() and linq (somewhere some kittens have died) but this page is a one off so not to fussed about performance.
    Regards
    Ismail
