  • Daniel Jensen 29 posts 160 karma points
    Sep 11, 2019 @ 13:56
    Daniel Jensen
    How to return view with a model from Surface controller
    Hi, I'm trying to post form data to a surface controller, and return a view saying something like "thanks for your form data entry {Name}".
    This is what my code is boiled down to: (It should illustrate what I wish to achieve)
    namespace Cookie.Web.Controllers
      public class WizardSurfaceController : SurfaceController
          [HttpPost]
          public ActionResult PassFormData()
            var formData = Request.Form;
            var name = formData["name"];
            var address = formData["address"];
            var email = formData["email"];
            var wvm = new WizardViewModel()
                Name = name,
                Address = address,
                Email = email
            return View("~/Views/statusPage.cshtml", wvm);
      public class WizardViewModel
          public string Name { get; set; }
          public string Address { get; set; }
          public string Email { get; set; }
    How do i pass data to my view? Its not a partial view, so it should also inherit the layout.
    If I try to run the snippet above, I just get this:
    Compiler Error Message: CS0115: 'PageViewsstatusPagecshtml.Execute()': no suitable method found to override
  • Shaishav Karnani from digitallymedia.com 354 posts 1638 karma points
    Sep 12, 2019 @ 05:36
    Hi Daniel,
    You need to return CurrentUmbracoPage();
    This is good article that shows how to pass data back to the front-end. https://our.umbraco.com/forum/using-umbraco-and-getting-started/98900-multi-step-form-implementation
    Shaishav
    Sep 12, 2019 @ 09:52
    Daniel Jensen
    @Shaishav It didn't seem to work with using the CurrentUmbracoPage(); It throws this error:
    System.InvalidOperationException: Can only use UmbracoPageResult in the context of an Http POST when using a SurfaceController form
    But RedirectToUmbracoPage(id, querystring); did work. It's however not quite what I was looking for. It will probably work if I either pass the data in the query string, or store it in the db, and pull it out in the razor template. It just seems farfetched from best practice.
