  • saurabh 6 posts 26 karma points
    Jan 24, 2011 @ 08:27
    saurabh
    Installation Problem with Umbraco 4.6.1 stuck on "Starter Kit Step"
    I'm also facing the problem during installation of Umbraco 4.6.1. I followed all the steps from provided documents. My development machine environment:
    OS: Windows 7 Enterprise
    IIS: 7.5
    Having Administrative rights
    Installation Steps:
    Step 1: Extract the package file 1.0.4029.25836.zip and placed my pc location "e:\test".
    Step 2: Making blank website in IIS with the name of "myumbraco" and mapped with "e:\test".
    Step 3: Configured following permissions on "e:\test" folder
    icacls . /grant "IIS APPPOOL\myumbraco":(OI)(CI)M
    icacls app_code /grant "IIS APPPOOL\myumbraco":(OI)(CI)RX
    icacls app_browsers /grant "IIS APPPOOL\myumbraco":(OI)(CI)RX
    icacls app_data /grant "IIS APPPOOL\myumbraco":(OI)(CI)M
    icacls bin /grant "IIS APPPOOL\myumbraco":(OI)(CI)R
    icacls config /grant "IIS APPPOOL\myumbraco":(OI)(CI)M
    icacls css /grant "IIS APPPOOL\myumbraco":(OI)(CI)M
    icacls data /grant "IIS APPPOOL\myumbraco":(OI)(CI)M
    icacls masterpages /grant "IIS APPPOOL\myumbraco":(OI)(CI)M
    icacls media /grant "IIS APPPOOL\myumbraco":(OI)(CI)M
    icacls python /grant "IIS APPPOOL\myumbraco":(OI)(CI)M
    icacls scripts /grant "IIS APPPOOL\myumbraco":(OI)(CI)M
    icacls umbraco /grant "IIS APPPOOL\myumbraco":(OI)(CI)R
    icacls usercontrols /grant "IIS APPPOOL\myumbraco":(OI)(CI)R
    icacls xslt /grant "IIS APPPOOL\myumbraco":(OI)(CI)M
    icacls web.config /grant "IIS APPPOOL\myumbraco":(OI)(CI)M
    icacls app_data\preview /grant "IIS APPPOOL\myumbraco":(OI)(CI)M
    icacls app_data\packages /grant "IIS APPPOOL\myumbraco":(OI)(CI)M
    Step 4: Having remote SQL 2008 Database Server. Create the database on that and provide sufficient user rights according to installation guide.
    Step 5: Browsing the localhost in IE. Installation process of Umbraco appeared and initial 4 steps are completed sucessfully stuck on 5th step:
    Starter kits
    To help you get started here are some basic starter kits. They have been tailored to suit common site configurations and install useful functionality such as blogs or image galleries.
    Mouse over the icons to learn more about what the starter kits will install.
    No connection to repository. Starter Kits could not be fetched from the repository as there was no connection to: 'http://packages.umbraco.org'
    Pls. help me to resolve the issue.
  • Daniel Bardi 927 posts 2562 karma points
    Jan 24, 2011 @ 08:42
    Daniel Bardi
    Make sure you can get to http://packages.umbraco.org in your browser without error.
    Repository might be down.
    Don't worry.. you should still be able to get to umbraco (http://localhost/umbraco/) and install packages and skins from the developer section when repository is available.
    Jan 24, 2011 @ 11:11
    saurabh
    Thanks for your reply...but I am checking the link 'http://packages.umbraco.org' for repository from last 3-4 days but still it is down.
    Hence stuck in "Starter Kit Step". Is there any other way to install umbraco.
  • Juan Manuel Rojas Cavaliere 1 post 21 karma points
    Jan 25, 2011 @ 17:11
    Saura did you get it?
    Jan 27, 2011 @ 06:30
    saurabh
    No dear I am still facing the same problem. 'http://packages.umbraco.org' link for repository is down. I think I have to go for any other CMS.
  • Raxit 26 posts 46 karma points
    Jan 27, 2011 @ 08:14
    Raxit
    Are you behind firewall?
    If Yes, you need to add following inside <system.net> section of your umbraco web.config file to bypass proxy
        <defaultProxy>
          <proxy proxyaddress="http://ProxyAddr:Port" bypassonlocal="True"/>
        </defaultProxy>
    Please ask your sysadmin to provide you the proxy address and port.
    HTH
    Jan 28, 2011 @ 07:49
    saurabh
    I tried bypassing the proxy also but getting same problem.
    'packages.umbraco.org' link even responding nothing on a system without any firewall.
    Jan 31, 2011 @ 13:30
    saurabh
    Whenever I exit from this step (repository) and want to start Umbraco it redirects me to the first step of Installation again.
  • Richard Kingston 46 posts 69 karma points
    Jan 31, 2011 @ 13:52
    Richard Kingston
    I too have this same problem - the repository appears to be down - I just get a blank screen whether I view it from my desktop PC at work, home laptop, or iPhone.
    And as per saurabh, localhost/umbraco sends me back to installation step 1.
    Do we have an update on the state of the repository? Is it a known issue?
    Feb 01, 2011 @ 14:30
    Richard Kingston
    Anyone? Is there a way to stop localhost/umbraco returning to install step 1 while the repository is down?
  • Facundo Herrera 1 post 21 karma points
    Feb 02, 2011 @ 14:54
    Facundo Herrera
    I had the same problem but finally I can solved it, I hope this can be useful for you guys too. The site http://packages.umbraco.org always was down (shows a blank page actually) so I changed the url in the browser from /install/?installStep=skinning (the step 5 where I stuck) to /install/?installStep=theend and It worked! (sorry for my Spanglish)
    Feb 03, 2011 @ 12:14
    Richard Kingston
    Hi Facundo,
    That's fantastic! Thank you very much.
    I'd had a guess at a few querystrings, like "step6", "end", "complete", "completed" but hadn't managed to find the right one.
    Brilliant.
    Rich
    Feb 04, 2011 @ 10:42
    saurabh
    Hi friend
    I tried the trick and changed the url as you said and installation completed.. but when I logined to umbraco Dashboard appear and getting errors like:
    Could not load control: '/umbraco/dashboard/startupdashboardintro.ascx'.
    Could not load control: '/umbraco/dashboard/startupdashboardkits.ascx'.
    Could not load control: '/umbraco/dashboard/startupdashboardvideos.ascx'.
    also if we create new content no document type is found..Step-5 which we bypassed is compulsary because it loads required packages for Umbraco
  • Adnan 1 post 21 karma points
    Mar 03, 2011 @ 17:28
    Adnan
    The problem above is caused because Umbraco expects to be installed in the root of the web server.
    I'd very much appreciate it if anybody could post instructions on how to place Umbraco with a sub-folder. Thanks.
  • kishore 0 posts 20 karma points
    Apr 15, 2011 @ 05:58
    kishore
    I got the same problem when I installed umbraco into a subdirectory. I had manually changed the paths to all the files to the new subdirectory ... ofcourse with the help of visual studio.
    for example. I installed in a umbraco subdirectory
    all the paths were intially pointing to /umbraco/.....
    I changed that to /umbraco/umbraco/....
    Now it is working fine.
    cheers!
